3.1.6 Traffic Lightο
Introductionο
In this project, we will use LED lights of three colors to realize the change of traffic lights and a four-digit 7-segment display will be used to display the timing of each traffic state.
Required Componentsο
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagramο
T-Board Name |
physical |
wiringPi |
BCM |
GPIO17 |
Pin 11 |
0 |
17 |
GPIO27 |
Pin 13 |
27 |
GPIO22 |
Pin 15 |
22 |
SPIMOSI |
Pin 19 |
12 |
10 |
GPIO18 |
Pin 12 |
18 |
GPIO23 |
Pin 16 |
23 |
GPIO24 |
Pin 18 |
24 |
GPIO25 |
Pin 22 |
25 |
SPICE0 |
Pin 24 |
10 |
8 |
SPICE1 |
Pin 26 |
11 |
7 |
Experimental Proceduresο
Step 1: Build the circuit.
Step 2: Change directory.
cd ~/raphael-kit/c/3.1.6/
Step 3: Compile.
gcc 3.1.6_TrafficLight.c -lwiringPi
Step 4: Run.
As the code runs, LEDs will simulate the color changing of traffic lights. Firstly, the red LED lights up for 60s, then the green LED lights up for 30s; next, the yellow LED lights up for 5s. After that, the red LED lights up for 60s once again. In this way, this series of actions will be executed repeatedly.
Codeο
#include <wiringPi.h>
#include <stdio.h>
#include <wiringShift.h>
#include <signal.h>
#include <unistd.h>
#define SDI 5
#define RCLK 4
#define SRCLK 1
const int ledPin[]={6,10,11};
const int placePin[] = {12, 3, 2, 0};
unsigned char number[] = {0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90};
int greenLight = 30;
int yellowLight = 5;
int redLight = 60;
int colorState = 0;
char *lightColor[]={"Red","Green","Yellow"};
int counter = 60;
void lightup()
for(int i=0;i<3;i++){
digitalWrite(ledPin[i],HIGH);
digitalWrite(ledPin[colorState],LOW);
void pickDigit(int digit)
for (int i = 0; i < 4; i++)
digitalWrite(placePin[i], 0);
digitalWrite(placePin[digit], 1);
void hc595_shift(int8_t data)
int i;
for (i = 0; i < 8; i++)
digitalWrite(SDI, 0x80 & (data << i));
digitalWrite(SRCLK, 1);
delayMicroseconds(1);
digitalWrite(SRCLK, 0);
digitalWrite(RCLK, 1);
digitalWrite(RCLK, 0);
void clearDisplay()
int i;
digitalWrite(SDI, 1);
void display()
int a,b,c;
a = counter % 10000 / 1000 + counter % 1000 / 100;
b = counter % 10000 / 1000 + counter % 1000 / 100 + counter % 100 / 10;
c = counter % 10000 / 1000 + counter % 1000 / 100 + counter % 100 / 10 + counter % 10;
if (counter % 10000 / 1000 == 0){
clearDisplay();
else{
clearDisplay();
pickDigit(3);
hc595_shift(number[counter % 10000 / 1000]);
if (a == 0){
clearDisplay();
else{
clearDisplay();
pickDigit(2);
hc595_shift(number[counter % 1000 / 100]);
if (b == 0){
clearDisplay();
else{
clearDisplay();
pickDigit(1);
hc595_shift(number[counter % 100 / 10]);
if(c == 0){
clearDisplay();
else{
clearDisplay();
pickDigit(0);
hc595_shift(number[counter % 10]);
void loop()
display();
lightup();
void timer(int timer1){ //Timer function
if(timer1 == SIGALRM){
counter --;
alarm(1);
if(counter == 0){
if(colorState == 0) counter = greenLight;
if(colorState == 1) counter = yellowLight;
if(colorState == 2) counter = redLight;
colorState = (colorState+1)%3;
printf("counter : %d \t light color: %s \n",counter,lightColor[colorState]);
int main(void)
int i;
if(wiringPiSetup() == -1){
pinMode(SDI,OUTPUT);
pinMode(RCLK,OUTPUT);
pinMode(SRCLK,OUTPUT);
for(i=0;i<4;i++){
pinMode(placePin[i],OUTPUT);
digitalWrite(placePin[i],HIGH);
for(i=0;i<3;i++){
pinMode(ledPin[i],OUTPUT);
signal(SIGALRM,timer);
alarm(1);
loop();
Code Explanationο
#define SDI 5
#define RCLK 4
#define SRCLK 1
void pickDigit(int digit);
void hc595_shift(int8_t data);
void clearDisplay();
void display();
These codes are used to realize the function of number display of 4-Digit 7-Segment Displays. Refer to chapter 1.1.5 of the document for more details. Here, we use the codes to display countdown of traffic light time.
int colorState = 0;
void lightup()
The codes are used to switch the LED on and off.
int redLight = 60;
int colorState = 0;
int counter = 60;
counter --;
alarm(1);
if(counter == 0){
The codes are used to switch the timer on and off. Refer to chapter 1.1.5 for more details. Here, when the timer returns to zero, colorState will be switched so as to switch LED, and the timer will be assigned to a new value.
void loop()
display();
lightup();
int main(void)
//β¦
alarm(1);
loop();
The timer is started in the main() function. In loop() function, use while(1) loop and call the functions of 4-Digit 7-Segment and LED.
Phenomenon Pictureο
