πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
2.1.8 Keypad
Introduction
A keypad is a rectangular array of buttons. In this project, We will use it input characters.
Required Components
../_images/list_2.1.5_keypad.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
Keypad
Schematic Diagram
../_images/image315.png ../_images/image316.png
Experimental Procedures
Step 1: Build the circuit.
../_images/image186.png
Step 2: Open the code file.
cd ~/raphael-kit/c/2.1.8/
Step 3: Compile the code.
gcc 2.1.8_Keypad.cpp -lwiringPi
Step 4: Run.
After the code runs, the values of pressed buttons on keypad (button Value) will be printed on the screen.
#include <wiringPi.h>
#include <stdio.h>
#define ROWS  4
#define COLS  4
'1','2','3','A',
'4','5','6','B',
'7','8','9','C',
'*','0','#','D'};
unsigned char rowPins[ROWS] = {1, 4, 5, 6};
unsigned char colPins[COLS] = {12, 3, 2, 0};
void init(void) {
    for(int i=0 ; i<4 ; i++) {
        pinMode(rowPins[i], OUTPUT);
        pinMode(colPins[i], INPUT);
int main(void){
    unsigned char pressed_keys[BUTTON_NUM];
    unsigned char last_key_pressed[BUTTON_NUM];
    init();
        keyRead(pressed_keys);
        if (!comp){
            keyPrint(pressed_keys);
            keyCopy(last_key_pressed, pressed_keys);
        delay(100);
void keyRead(unsigned char* result){
    int index;
    int count = 0;
    keyClear(result);
    for(int i=0 ; i<ROWS ; i++ ){
        digitalWrite(rowPins[i], HIGH);
        for(int j =0 ; j < COLS ; j++){
            index = i * ROWS + j;
            if(digitalRead(colPins[j]) == 1){
                result[count]=KEYS[index];
                count += 1;
        delay(1);
        digitalWrite(rowPins[i], LOW);
bool keyCompare(unsigned char* a, unsigned char* b){
    for (int i=0; i<BUTTON_NUM; i++){
        if (a[i] != b[i]){
            return false;
    return true;
void keyCopy(unsigned char* a, unsigned char* b){
        a[i] = b[i];
void keyPrint(unsigned char* a){
    if (a[0] != 0){
        printf("%c",a[0]);
    for (int i=1; i<BUTTON_NUM; i++){
        if (a[i] != 0){
            printf(", %c",a[i]);
    printf("\n");
void keyClear(unsigned char* a){
        a[i] = 0;
int keyIndexOf(const char value){
        if ((const char)KEYS[i] == value){
            return i;
    return -1;
Code Explanation
'1','2','3','A',
'4','5','6','B',
'7','8','9','C',
'*','0','#','D'};
Declare each key of the matrix keyboard to the array keys[] and define the pins on each row and column.
        if (!comp){
        delay(100);
This is the part of the main function that reads and prints the button value.
The function keyRead() will read the state of every button.
KeyCompare() and keyCopy() are used to judge whether the state of a button has changed (that is, a button has been pressed or released).
keyPrint() will print the button value of the button whose current level is high level (the button is pressed).
    int index;
    int count = 0;
    keyClear(result);
                count += 1;
        delay(1);
This function assigns a high level to each row in turn, and when the key in the column is pressed, the column in which the key is located gets a high level. After the two-layer loop judgment, the key state compilation will generate an array (reasult[]).
When pressing button 3:
../_images/image187.png
RowPin [0] writes in the high level, and colPin[2] gets the high level. ColPin [0], colPin[1], colPin[3] get the low level.
This gives us 0,0,1,0. When rowPin[1], rowPin[2] and rowPin[3] are written in high level, colPin[0]~colPin[4] will get low level.
After the loop judgment is completed, an array will be generated:
result[BUTTON_NUM] {
0, 0, 1, 0,
0, 0, 0, 0,
0, 0, 0, 0,
0, 0, 0, 0};
        if (a[i] != b[i]){
            return false;
    return true;
        a[i] = b[i];
These two functions are used to judge whether the key state has changed, for example when you release your hand when pressing β€˜3’ or pressing β€˜2’, keyCompare() returns false.
KeyCopy() is used to re-write the current button value for the a array (last_key_pressed[BUTTON_NUM]) after each comparison. So we can compare them next time.
//printf("{");
    if (a[0] != 0){
        printf("%c",a[0]);
        if (a[i] != 0){
    printf("\n");
This function is used to print the value of the button currently pressed. If the button β€˜1’ is pressed, the β€˜1’ will be printed. If the button β€˜1’ is pressed and the button β€˜3’ is pressed, the β€˜1, 3’ will be printed.
Phenomenon Picture
../_images/image188.jpeg
