2.15 Two Kinds of Transistors
In this lesson, we’ll explore two types of transistors: the S8050 (NPN) and the S8550 (PNP). Transistors are commonly used as electronic switches, and we’ll see how both types can be used to control an LED with a button.
img_NPN&PNP
  • NPN (S8050): This type of transistor allows current to flow from the collector to the emitter when a high signal is applied to the base.
  • PNP (S8550): For PNP transistors, current flows from the emitter to the collector when a low signal is applied to the base.
While both transistors serve similar purposes, they behave oppositely when it comes to signal control. Let’s use these transistors to control an LED based on button input.
Transistor
ITEMS IN THIS KIT
Pico 2 W Starter Kit
450+
Pico 2 W Kit
SN
COMPONENT
QUANTITY
Getting to Know Pico 2 W
Micro USB Cable
Jumper Wires
Several
Resistor
3(220Ω, 1KΩ, 10KΩ)
LED
Button
Transistor
1(S8050/S8550)
Way to connect NPN (S8050) transistor
sch_s8050
In this circuit, pressing the button sends a high signal to the GP14 pin. When GP15 outputs a high signal, the NPN transistor conducts, allowing current to flow through the LED, lighting it up.
wiring_s8050
Way to connect PNP(S8550) transistor
sch_s8550
For the PNP transistor circuit, the button starts with a low signal on GP14 and changes to high when pressed. When GP15 outputs a low signal, the PNP transistor conducts, allowing current to flow and lighting up the LED.
wiring_s8550
Writing the Code
Both the NPN and PNP transistors can be controlled with the same code. The button’s status is read, and depending on whether it’s pressed or not, the Pico outputs a high or low signal to GP15.
  • Open the 2.15_transistor.py from pico-2w-kit-main/micropython or copy the code into Thonny, then click “Run” or press F5.
  • Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
import machine
# Initialize the button and signal pins
button = machine.Pin(14, machine.Pin.IN)
signal = machine.Pin(15, machine.Pin.OUT)
    button_status = button.value()
    if button_status == 1:
        signal.value(1)  # Send high signal to the transistor
        signal.value(0)  # Send low signal to the transistor
Results
  • NPN Circuit (S8050):
    The LED lights up when the button is pressed because the NPN transistor conducts when a high signal is applied to its base.
  • PNP Circuit (S8550):
    The LED lights up when the button is released because the PNP transistor conducts when a low signal is applied to its base.
Both circuits demonstrate how transistors can be used to control current flow based on different types of signals.
Conclusion
By experimenting with these two transistors, you gain a better understanding of how NPN and PNP transistors function and how to use them in circuits to control electronic devices.
