2.16 Control Another Circuit
In this lesson, we will learn how to control another circuit using a relay and the Raspberry Pi Pico 2 W. A relay acts like a switch controlled by a low-voltage circuit (like Pico) to operate a high-voltage circuit. For example, you can use a relay to turn on a lamp or any other device, making it possible to automate electrical appliances.
Warning
Modification of electrical appliances comes with great danger, do not try it lightly, please do it under the guidance of professionals.
Here we only use a simple circuit powered by a breadboard power module as an example to show how to control it using relay.
Pico 2 W Starter Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
1(S8050) |
7 |
First, build a low-voltage circuit for controlling a relay. Driving the relay requires a high current, so a transistor is needed, and here we use the S8050.
Relay Activation:
The relay’s coil is energized by the transistor when the Pico outputs a high signal (3.3V) to GP15.
The transistor allows current to flow through the relay, activating the switch inside.
The relay makes a “click” sound when switching, indicating the control of the load circuit.
Flyback Diode:
The diode is placed across the relay coil to protect the transistor from voltage spikes that occur when the relay is turned off.
Wiring Diagram
The following code will control the relay, switching the connected circuit on and off every two seconds.
Open the
2.16_control_another_circuit.pyfrompico-2w-kit-main/micropythonor copy the code into Thonny, then click “Run” or press F5.Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
import machine
import utime
# Initialize the relay pin on GP15
relay = machine.Pin(15, machine.Pin.OUT)
relay.value(1) # Turn the relay on
utime.sleep(2) # Wait for 2 seconds
relay.value(0) # Turn the relay off
When the code is running, you should hear a “click” sound from the relay every two seconds, indicating the circuit is being switched on and off.
Experimenting Further
Set a Timer: Modify the code to turn the relay on for 10 minutes and then automatically turn it off.
Control Home Appliances: With appropriate guidance, you can connect high-voltage devices to the relay for automation tasks such as turning lights or fans on and off.
The circuit should look like this: To demonstrate controlling an external circuit safely, we’ll add an Li-po Charger Module to power an LED. This simulates how you could control higher voltage devices (like home appliances) . Here’s how to modify the circuit:
Code to Control the Relay:
import machine import utime # Initialize the relay pin on GP15 relay = machine.Pin(15, machine.Pin.OUT) while True: relay.value(1) # Turn the relay on utime.sleep(2) # Wait for 2 seconds relay.value(0) # Turn the relay off utime.sleep(2) # Wait for 2 seconds
When the relay is activated (GP15 outputs high), the Normally Open (NO) and Common (C) pins of the relay connect, allowing the external Li-po Charger Module to flow through the LED. The LED will light up, simulating how a relay can control an external appliance.
When the relay is deactivated (GP15 outputs low), the Normally Open (NO) pin disconnects from the Common (C) pin, cutting off the external power, and the LED turns off.
Safety Considerations for Controlling Real Appliances
This example uses an LED and Li-po Charger Module to demonstrate relay control. If you are controlling higher voltage devices (like household appliances), ensure:
Proper Voltage Rating: Use a relay rated for the appropriate voltage and current for your appliance.
Isolation: For safety, ensure proper isolation between the low-voltage control circuit (like the Pico) and the high-voltage appliance circuit.
Fuse Protection: Consider adding fuses or circuit breakers to protect against short circuits or overloads.
Professional Guidance: When working with high-voltage circuits, always seek professional guidance to ensure safe operation.
This project can serve as the basis for home automation, such as controlling lamps, fans, or other devices based on timers or sensors connected to the Raspberry Pi Pico 2 W.
Using the NC Terminal
If you connect your controlled circuit between COM and NC:
The circuit will be closed (ON) when the relay is not energized.
The circuit will be open (OFF) when the relay is energized.
Example: Controlling an External Device
Warning: Do not attempt to control high-voltage devices without proper knowledge and safety precautions.
If you want to control a small DC motor or another device:
Replace the LED with the device you want to control.
Ensure the device’s voltage and current requirements are compatible.
Provide an appropriate power supply for the device.
Connect the device in series with the relay’s COM and NO (or NC) terminals.
Conclusion
By using the relay to control an external circuit, you’ve learned how to switch on and off external devices, such as LEDs or even higher voltage appliances. This opens the door to creating automated smart devices that can be controlled through code, offering endless possibilities for home automation and other projects.
