2.3 Fading LED
In this lesson, we’ll learn how to control the brightness of an LED using Pulse Width Modulation (PWM) on the Raspberry Pi Pico 2 W. This is a fundamental technique in electronics that allows us to control devices like LEDs and motors with varying intensities.
What is PWM?
Pulse Width Modulation (PWM) is a method of controlling the amount of power delivered to an electronic device by cycling the power on and off at a high frequency. The “width” of the pulse (the duration it stays on) determines how much power the device receives.
Duty Cycle: The percentage of one period in which a signal is active. A 100% duty cycle means the signal is always on, and 0% means it’s always off.
Frequency: How often the signal cycles on and off per second.
By adjusting the duty cycle, we can simulate analog output using digital signals. For example, if we rapidly turn an LED on and off, our eyes perceive varying brightness levels depending on how long the LED stays on during each cycle.
Why Use PWM?
LED Brightness Control: Smoothly adjust the brightness of LEDs.
Motor Speed Control: Control the speed of DC motors.
Efficiency: PWM is more efficient than using variable resistors because it reduces energy loss in the form of heat.
Understanding PWM on the Raspberry Pi Pico 2 W
The Raspberry Pi Pico 2 W has PWM capabilities on all its GPIO pins, but it actually has 8 PWM slices (from PWM0 to PWM7), each with two channels (A and B), giving a total of 16 independent PWM outputs.
Pins sharing the same PWM slice (like GP0 and GP16) cannot have different frequencies but can have different duty cycles.
Pico 2 W Starter Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
1(220Ω) |
Circuit Diagram
Wiring Diagram
Writing the Code
Open the
2.3_fading_led.pyfrompico-2w-kit-main/micropythonor copy the code into Thonny, then click “Run” or press F5.Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
import machine
import utime
# Set up PWM on pin GP15
led = machine.PWM(machine.Pin(15))
led.freq(1000) # Set frequency to 1000Hz
# Gradually increase brightness
for duty in range(0, 65536, 64):
led.duty_u16(duty) # Set duty cycle (16-bit value)
utime.sleep(0.01) # Wait 10ms
# Turn off the LED
led.duty_u16(0)
When the code is running, the LED connected to pin GP15 will gradually increase in brightness from off to full brightness.
Understanding the Code
Import Libraries:
machine: Provides access to the hardware components.utime: Allows us to add delays.
Set Up PWM:
machine.PWM(machine.Pin(15)): Initializes PWM on GP15.led.freq(1000): Sets the PWM frequency to 1000Hz (1ms per cycle).
Adjust Duty Cycle:
for duty in range(0, 65536, 64): Loops from 0 to 65535 in steps of 64.led.duty_u16(duty): Sets the duty cycle. Theduty_u16function accepts a 16-bit value (0 to 65535), where 0 is 0% and 65535 is 100% duty cycle.utime.sleep(0.01): Adds a small delay so the change in brightness is perceptible.
Turn Off the LED:
led.duty_u16(0): Sets the duty cycle to 0%, turning off the LED.
Experimenting Further
Fade In and Out: Modify the code to make the LED fade in and then fade out.
Change Speed: Adjust the
utime.sleep()value to change how quickly the brightness changes.Different Frequencies: Try different PWM frequencies using
led.freq()to see how it affects the LED.
Conclusion
PWM is a powerful technique for controlling devices that require analog-like inputs using digital outputs. Understanding PWM opens up possibilities for more complex projects like motor control, audio signal generation, and more.
By mastering the basics of PWM on the Raspberry Pi Pico 2 W, you’re well on your way to creating more advanced electronics projects.
References
