2.2 Display the Level
In this lesson, we’ll learn how to control an LED Bar Graph using the Raspberry Pi Pico . An LED Bar Graph consists of 10 LEDs arranged in a line, typically used to display levels such as volume, signal strength, or other measurements. We’ll light up the LEDs sequentially to create a level display effect.
Pico 2 W Starter Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
10(220Ω) |
Circuit Diagram
In this project, each of the 10 LEDs in the LED Bar Graph is connected to the Raspberry Pi Pico 2 W. The anodes (positive terminals) of the LEDs are connected to GPIO pins GP6 through GP15. The cathodes (negative terminals) are connected through 220Ω resistors to the GND (ground) pin.
Wiring Diagram
Writing the Code
Open the
2.2_display_the_level.pyfile under the path ofpico-2w-kit-main/micropythonor copy this code into Thonny, then click “Run Current Script” or simply press F5 to run it.Make sure the “MicroPython (Raspberry Pi Pico).COMxx” interpreter is selected in the bottom right corner of Thonny.
import machine
import utime
# Define the GPIO pins connected to the LEDs
pins = [6, 7, 8, 9, 10, 11, 12, 13, 14, 15]
leds = []
# Initialize each pin as an output and store it in the leds list
for pin_number in pins:
led = machine.Pin(pin_number, machine.Pin.OUT)
leds.append(led)
# Turn on LEDs one by one to simulate increasing level
for led in leds:
led.value(1) # Turn the LED on
utime.sleep(0.2)
# Turn off LEDs one by one to simulate decreasing level
for led in leds:
led.value(0) # Turn the LED off
utime.sleep(0.2)
When you run the program, the LEDs on the LED Bar Graph will light up sequentially from the first to the last, creating an increasing level effect. Then, they will turn off one by one, simulating a decreasing level.
Understanding the Code
In this project, we control multiple LEDs using lists and loops in MicroPython, which makes the code efficient and easy to read.
Let’s break down the key parts of the code:
Importing Modules:
import machine: Provides access to the Raspberry Pi Pico 2 W’s hardware functionalities.import utime: Allows us to use time-related functions like delays.
Defining Pins and Initializing LEDs:
We create a list
pinscontaining the GPIO pin numbers connected to the LEDs and initialize an empty listledsto store the LED objects.# Define the GPIO pins connected to the LEDs pins = [6, 7, 8, 9, 10, 11, 12, 13, 14, 15] leds = []
Using a
forloop, we iterate over each pin number, set it as an output pin, and append the correspondingPinobject to theledslist.for pin_number in pins: led = machine.Pin(pin_number, machine.Pin.OUT) leds.append(led)
Creating the Level Display Effect:
The
while True:loop runs indefinitely.Increasing Level:
Use a
forloop to iterate over eachledin theledslist.led.value(1)turns the LED on.utime.sleep(0.2)adds a 200ms delay before the next LED turns on.
for led in leds: led.value(1) utime.sleep(0.2)
Decreasing Level:
Turn off each LED one by one using another
forloop.led.value(0)turns the LED off.
for led in leds: led.value(0) utime.sleep(0.2)
Experimenting Further
Feel free to experiment with the code:
Change the Speed:
Adjust the delay in
utime.sleep(0.2)to make the LEDs light up faster or slower.
Reverse the Order:
Use
reversed(leds)to reverse the sequence of the LEDs.for led in reversed(leds): led.value(1) utime.sleep(0.2)
Create a Ping-Pong Effect:
Make the LEDs light up from left to right and then back from right to left.
while True: for led in leds: led.value(1) utime.sleep(0.1) for led in reversed(leds): led.value(0) utime.sleep(0.1)
Conclusion
By controlling each LED individually, we’ve created a simple yet effective level display using the Raspberry Pi Pico 2 W. This project demonstrates the power of lists and loops in Python, allowing us to manage multiple outputs efficiently.
Understanding how to work with multiple GPIO pins and using programming structures like lists and loops is essential for more complex projects, such as creating animations, controlling multiple sensors, or building interactive devices.
References
