šŸ‘‰ Ready to explore and create with us? Click [here] and join today!
3.7 Swinging Servo
In this lesson, we’ll learn how to control a servo motor using the Raspberry Pi Pico 2 W. A servo motor is a device that can rotate to a specific angle between 0° and 180°. It’s widely used in remote control toys, robots, and other applications that require precise position control.
Let’s get started and make the servo swing back and forth!
ITEMS IN THIS KIT
Pico 2 W Starter Kit
450+
Pico 2 W Kit
SN
COMPONENT
QUANTITY
Getting to Know Pico 2 W
Micro USB Cable
Jumper Wires
Several
Servo
Schematic
sch_servo
wiring_servo
  • Orange wire is signal and connected to GP15.
  • Red wire is VCC and connected to VBUS(5V).
  • Brown wire is GND and connected to GND.
Servos can draw significant current, especially under load. Since we’re using a small servo and not putting it under heavy load, powering it from the Pico’s VBUS pin is acceptable for this simple experiment. For larger servos or multiple servos, use an external power supply.
Setting Up the Servo Arm
  • Attach the servo arm (also called a horn) to the servo’s output shaft.
  • Secure it with the small screw provided with the servo if necessary.
Writing the Code
We’ll write a MicroPython program to make the servo sweep back and forth between 0° and 180°.
  • Open the 3.7_swinging_servo.py from pico-2w-kit-main/micropython or copy the code into Thonny, then click ā€œRunā€ or press F5.
  • Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
import machine
import utime
# Initialize PWM on pin GP15
servo = machine.PWM(machine.Pin(15))
servo.freq(50)  # Set the frequency to 50Hz
# Function to map angle to duty cycle
def angle_to_duty(angle):
    min_duty = 1638  # Corresponds to 0.5ms pulse (0°)
    max_duty = 8192  # Corresponds to 2.5ms pulse (180°)
    duty = int(min_duty + (angle / 180) * (max_duty - min_duty))
    return duty
    # Move servo from 0° to 180°
    for angle in range(0, 181, 1):
        servo.duty_u16(angle_to_duty(angle))
        utime.sleep_ms(20)
    # Move servo from 180° back to 0°
    for angle in range(180, -1, -1):
        utime.sleep_ms(20)
When the code is running, the servo should smoothly sweep back and forth between 0° and 180°.
Understanding the Code
  1. Import Modules:
    • machine: Provides access to hardware-related functions.
    • utime: Contains time-related functions for delays.
  2. Initialize PWM:
    We set up PWM on GP15. The frequency is set to 50Hz, which is standard for servos.
    servo.freq(50)
  3. Define the angle_to_duty Function:
    • This function maps an angle (0° to 180°) to the corresponding duty cycle value for the servo.
    • The min_duty and max_duty correspond to the minimum and maximum pulse widths for the servo control signal.
    • The calculation scales the angle to the appropriate duty cycle.
        min_duty = 1638  # 0.5ms pulse width
        max_duty = 8192  # 2.5ms pulse width
        return duty
  4. Main Loop to Move the Servo:
    • The servo moves from 0° to 180°, increasing the angle by 1° each time.
    • Then it moves back from 180° to 0°.
    • utime.sleep_ms(20) adds a small delay to smooth the movement.
            utime.sleep_ms(20)
            utime.sleep_ms(20)
More about the Code
Servos are controlled by sending a PWM signal with a specific pulse width. A 50Hz PWM signal (period of 20ms) is standard for servos. The pulse width within each period determines the servo’s angle:
  • 0.5ms pulse width corresponds to 0°.
  • 1.5ms pulse width corresponds to 90°.
  • 2.5ms pulse width corresponds to 180°.
By adjusting the duty cycle of the PWM signal, we change the pulse width.
The duty_u16() function accepts values from 0 to 65535. To calculate the duty cycle corresponding to a pulse width:
Duty cycle = (Pulse Width / Period) * 65535
For example, for a 0.5ms pulse width:
Duty cycle = (0.5ms / 20ms) * 65535 ā‰ˆ 1638
Experimenting Further
  • Change the Speed: Adjust the utime.sleep_ms(20) delay to make the servo move faster or slower.
  • Set Specific Angles: Modify the code to move the servo to specific angles.
    servo.duty_u16(angle_to_duty(90))  # Move to 90°
  • Control with Input: Connect a potentiometer or buttons to control the servo’s angle interactively.
Important Notes
  • Power Supply: Ensure the servo is powered adequately. If you notice jitter or erratic movement, consider using an external 5V power supply for the servo.
  • Avoid Overloading: Do not force the servo beyond its physical limits (usually 0° to 180°) to prevent damage.
Conclusion
In this lesson, you’ve learned how to control a servo motor using the Raspberry Pi Pico 2 W. You now understand how to generate PWM signals to set the servo’s angle and make it move smoothly. This skill is fundamental for robotics and automation projects where precise movement is required.
