2.2 - Display the Level
In this lesson, we’ll learn how to control an LED Bar Graph using the Raspberry Pi Pico 2 W. An LED Bar Graph consists of 10 LEDs arranged in a line, typically used to display levels such as volume, signal strength, or other measurements. We’ll light up the LEDs sequentially to create a level display effect.
PURCHASE LINK |
Pico 2 W Starter Kit |
450+ |
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Micro USB Cable |
Several |
10(220Ω) |
Schematic
The LED Bar Graph contains 10 LEDs, each of which is individually controllable. Here, the anode of each of the 10 LEDs is connected to GP6~GP15, and the cathode is connected to a 220ohm resistor, and then to GND.
Writing the Code
You can open the file
2.2_display_the_level.inounder the path ofpico-2w-kit-main/arduino/2.2_display_the_level.Or copy this code into Arduino IDE.
Don’t forget to select the board(Raspberry Pi Pico) and the correct port before clicking the Upload button.
// Define the GPIO pins connected to the LED Bar Graph
const int ledPins[] = {6, 7, 8, 9, 10, 11, 12, 13, 14, 15};
// Initialize each pin as an output
for (int i = 0; i < 10; i++) {
pinMode(ledPins[i], OUTPUT);
// Turn on LEDs sequentially
digitalWrite(ledPins[i], HIGH); // Turn on LED
delay(500); // Wait 500 milliseconds
digitalWrite(ledPins[i], LOW); // Turn off LED
After uploading the code, the LEDs on the bar graph should light up one after another, creating a level display effect. Each LED turns on for half a second and then turns off before the next one lights up.
Understanding the Code
Defining the LED Pins:
Create an array
ledPinsthat holds the GPIO pin numbers connected to each LED on the bar graph.const int ledPins[] = {6, 7, 8, 9, 10, 11, 12, 13, 14, 15};
Initializing the Pins:
In the
setup()function, we set each pin in theledPinsarray as an output.void setup() { for (int i = 0; i < 10; i++) { pinMode(ledPins[i], OUTPUT); } }
Controlling the LEDs:
In the
loop()function, we use aforloop to iterate through each LED. We turn it on, wait for 500 milliseconds, turn it off, and then wait another 500 milliseconds before moving to the next LED.void loop() { for (int i = 0; i < 10; i++) { digitalWrite(ledPins[i], HIGH); delay(500); digitalWrite(ledPins[i], LOW); delay(500); } }
Experimenting Further
Reverse the Order: Modify the code to light up the LEDs in reverse order.
Create a Bounce Effect: After reaching the last LED, make the sequence reverse back to the first LED.
void loop() { // Ascending sequence for (int i = 0; i < 10; i++) { digitalWrite(ledPins[i], HIGH); delay(200); digitalWrite(ledPins[i], LOW); } // Descending sequence for (int i = 8; i >= 0; i--) { digitalWrite(ledPins[i], HIGH); delay(200); digitalWrite(ledPins[i], LOW); } }
Adjust the Speed: Change the delay times to make the LEDs light up faster or slower.
Conclusion
In this lesson, you’ve learned how to control multiple LEDs using the Raspberry Pi Pico and how to create visual effects using simple programming constructs like loops and delays. This foundational knowledge is essential for more advanced projects involving LED displays and indicators.
