2.6 Tilt It!
In this lesson, we’ll learn how to use a tilt switch with the Raspberry Pi Pico 2 W to detect changes in orientation. A tilt switch is a simple device that can sense whether it is upright or tilted, making it useful for applications like motion detection, orientation sensing, or as a trigger based on position.
ITEMS IN THIS KIT
PURCHASE LINK
Pico 2 W Starter Kit
450+
Pico 2 W Kit
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Getting to Know Pico 2 W
Micro USB Cable
Jumper Wires
Several
Resistor
1(10KΩ)
Tilt Switch
Schematic
sch_tilt
  • When Upright (Switch Closed):
    • The tilt switch connects 3.3V directly to GP14.
    • The GPIO pin reads HIGH (1).
  • When Tilted (Switch Open):
    • The tilt switch disconnects 3.3V from GP14.
    • The pull-down resistor pulls GP14 to GND.
    • The GPIO pin reads LOW (0).
wiring_tilt
Writing the Code
  • You can open the file 2.6_tilt_it.ino under the path of pico-2w-kit-main/arduino/2.4_colorful_light.
  • Don’t forget to select the board(Raspberry Pi Pico) and the correct port before clicking the Upload button.
const int tiltPin = 14;  // GPIO pin connected to the tilt switch
  Serial.begin(115200);       // Initialize Serial Monitor at 115200 baud
  pinMode(tiltPin, INPUT);    // Set the tilt pin as input
  int tiltState = digitalRead(tiltPin);  // Read the state of the tilt switch
  if (tiltState == HIGH) {
    Serial.println("The switch works!");
  delay(100);  // Small delay to avoid flooding the Serial Monitor
When the code is running, and the Serial Monitor is open, tilt the breadboard or the tilt switch. Each time you tilt the switch to the upright position, “The switch works!” should appear in the Serial Monitor.
Understanding the Code
  1. Initializing Serial Communication:
    Starts serial communication at a baud rate of 115200. This allows us to print messages to the Serial Monitor.
  2. Setting Up the Tilt Pin:
    Configures tiltPin (GP14) as an input to read the state of the tilt switch.
  3. Reading the Tilt Switch State:
    Reads the current state of the tilt switch. It will be HIGH when upright and LOW when tilted.
  4. Responding to Tilt:
    If the tilt switch is upright (closed), print a message to the Serial Monitor.
Experimenting Further
  • Control an LED: Modify the code to turn an LED on when the tilt switch is upright and off when tilted.
    const int ledPin = 15;    // GPIO pin connected to an LED
      pinMode(ledPin, OUTPUT);
        digitalWrite(ledPin, HIGH);  // Turn on LED
      } else {
        digitalWrite(ledPin, LOW);   // Turn off LED
      delay(100);
  • Adjust Sensitivity: Some tilt switches have different sensitivity levels. Experiment by adjusting the orientation to see at what angle the switch activates.
Conclusion
In this lesson, you’ve learned how to use a tilt switch with the Raspberry Pi Pico to detect changes in orientation. This fundamental skill allows you to create projects that respond to movement or position, such as alarms, automatic lighting, or interactive devices.
