2.3 Fading LED
In this lesson, we’ll learn how to control the brightness of an LED using Pulse Width Modulation (PWM) on the Raspberry Pi Pico 2 W. This is a fundamental technique in electronics that allows us to control devices like LEDs and motors with varying intensities.
What is PWM?
Pulse Width Modulation (PWM) is a method of controlling the amount of power delivered to an electronic device by cycling the power on and off at a high frequency. The “width” of the pulse (the duration it stays on) determines how much power the device receives.
Duty Cycle: The percentage of one period in which a signal is active. A 100% duty cycle means the signal is always on, and 0% means it’s always off.
Frequency: How often the signal cycles on and off per second.
By adjusting the duty cycle, we can simulate analog output using digital signals. For example, if we rapidly turn an LED on and off, our eyes perceive varying brightness levels depending on how long the LED stays on during each cycle.
Why Use PWM?
LED Brightness Control: Smoothly adjust the brightness of LEDs.
Motor Speed Control: Control the speed of DC motors.
Efficiency: PWM is more efficient than using variable resistors because it reduces energy loss in the form of heat.
Understanding PWM on the Raspberry Pi Pico 2 W
The Raspberry Pi Pico 2 W has PWM capabilities on all its GPIO pins, but it actually has 8 PWM slices (from PWM0 to PWM7), each with two channels (A and B), giving a total of 16 independent PWM outputs.
Pins sharing the same PWM slice (like GP0 and GP16) cannot have different frequencies but can have different duty cycles.
PURCHASE LINK |
Pico 2 W Starter Kit |
450+ |
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Micro USB Cable |
Several |
1(220Ω) |
Schematic
Writing the Code
You can open the file
2.3_fading_led.inounder the path ofpico-2w-kit-main/arduino/2.3_fading_led.Or copy this code into Arduino IDE.
Don’t forget to select the board(Raspberry Pi Pico) and the correct port before clicking the Upload button.
const int ledPin = 15; // GPIO pin connected to the LED
pinMode(ledPin, OUTPUT); // Initialize the GPIO pin as an output
// Increase brightness
for (int value = 0; value <= 255; value += 5) {
analogWrite(ledPin, value); // Set the brightness
delay(30); // Wait for 30 milliseconds
// Decrease brightness
for (int value = 255; value >= 0; value -= 5) {
delay(30);
After uploading the code, you should see the LED gradually increase in brightness and then fade, creating a smooth pulsing effect.
Understanding the Code
Declaring the LED Pin:
Declare a constant integer
ledPinand assign it the value 15, which corresponds to GPIO pin 15 where the LED is connected.const int ledPin = 15;
Setting Up the Pin:
The
setup()function runs once when the board powers up. We initializeledPinas an output usingpinMode().void setup() { pinMode(ledPin, OUTPUT); }
The Loop Function:
The
loop()function runs repeatedly. It contains twoforloops:Increasing Brightness: Starts with
value = 0and increases by 5 until it reaches 255.Decreasing Brightness: Starts with value = 255 and decreases by 5 down to 0.
The
analogWrite()function writes a PWM signal to the specified pin. The value ranges from 0 (always off) to 255 (always on), allowing for 256 levels of brightness.Adding
delay(30);slows down the loop, so the change in brightness is gradual and visible to the human eye.
void loop() { // Increase brightness for (int value = 0; value <= 255; value += 5) { analogWrite(ledPin, value); delay(30); } // Decrease brightness for (int value = 255; value >= 0; value -= 5) { analogWrite(ledPin, value); delay(30); } }
Additional Tips
Experiment: Try changing the value increments or the delay duration to see how it affects the fading speed.
Understanding PWM Limitations: While all GPIO pins on the Pico support PWM, pins sharing the same PWM slice cannot have different frequencies but can have different duty cycles.
Safety First: Always use a resistor with the LED to prevent it from drawing too much current and burning out.
Conclusion
You’ve successfully created a fading LED effect using PWM on the Raspberry Pi Pico 2 W. This project demonstrates how PWM can be used to simulate analog behavior with digital signals, a fundamental concept in electronics and programming microcontrollers.
