2.8 - Press Gently
In this lesson, we’ll learn how to use a micro switch (also known as a limit switch) with the Raspberry Pi Pico 2 W to detect when it’s pressed or released. Micro switches are commonly used in devices like microwave oven doors, printer covers, or as end stops in 3D printers because they are reliable and can handle frequent activation.
PURCHASE LINK |
Pico 2 W Starter Kit |
450+ |
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Micro USB Cable |
Several |
1(10KΩ) |
1(104) |
7 |
Understanding the Micro Switch
A micro switch typically has three pins:
Common (C): The middle pin.
Normally Open (NO): Connected to the common pin when the switch is pressed.
Normally Closed (NC): Connected to the common pin when the switch is not pressed.
By connecting the switch appropriately, we can detect when it’s pressed by reading the voltage level on a GPIO pin.
Schematic
By default, GP14 is low and when pressed, GP14 is high.
The purpose of the 10K resistor is to keep the GP14 low during pressing.
When you press a mechanical switch, the contacts may bounce, causing multiple rapid transitions between open and closed states. The capacitor connected between GP14 and GND helps filter out this noise.
Switch Not Pressed:
The Common (C) pin is connected to the NC pin, which is connected to GND.
GP14 reads LOW (0V).
Switch Pressed:
The Common (C) pin is connected to the NO pin, which is connected to 3.3V.
GP14 reads HIGH (3.3V).
Writing the Code
We’ll write a simple program that detects when the micro switch is pressed and prints a message to the Serial Monitor.
You can open the file
2.8_press_gently.inounder the path ofpico-2w-kit-main/arduino/2.8_press_gently.Or copy this code into Arduino IDE.
Don’t forget to select the board(Raspberry Pi Pico) and the correct port before clicking the Upload button.
const int switchPin = 14; // GPIO pin connected to the micro switch
int switchState = 0;
Serial.begin(115200); // Initialize Serial Monitor at 115200 baud
pinMode(switchPin, INPUT); // Set the switch pin as input
switchState = digitalRead(switchPin); // Read the state of the switch
if (switchState == HIGH) {
Serial.println("The switch is pressed!");
} else {
Serial.println("The switch is not pressed.");
delay(200); // Small delay to avoid flooding the Serial Monitor
When the code is running and the Serial Monitor is open, press and release the micro switch. The Serial Monitor will display “The switch is pressed!” when you press the switch and “The switch is not pressed.” when you release it.
Understanding the Code
Initializing Serial Communication:
Starts serial communication at a baud rate of 115200. This allows us to print messages to the Serial Monitor.
Setting Up the Switch Pin:
Configures switchPin (GP14) as an input to read the switch state.
Reading the Switch State:
Reads the current state of the switch. It will be HIGH when pressed and LOW when not pressed.
Responding to Switch Press:
Prints a message based on whether the switch is pressed or not.
if (switchState == HIGH) { Serial.println("The switch is pressed!"); } else { Serial.println("The switch is not pressed."); }
Alternative: Using Internal Pull-Up Resistor
If you prefer to simplify the circuit and reduce the number of components, you can use the internal pull-up resistor of the Pico.
GP14 is connected to GND when the switch is pressed, so it reads LOW (0).
GP14 reads HIGH when the switch is not pressed due to the internal pull-up resistor.
Circuit Modifications:
Remove the External 10KΩ Resistor and Capacitor.
Micro Switch Connections:
Common (C) Terminal: Connect to GP14 on the Pico.
Normally Open (NO) Terminal: Connect to GND on the Pico.
Normally Closed (NC) Terminal: Leave unconnected.
Code Modifications:
const int switchPin = 14; // GPIO pin connected to the micro switch int switchState = 0; void setup() { Serial.begin(115200); // Initialize Serial Monitor at 115200 baud pinMode(switchPin, INPUT_PULLUP); // Enable internal pull-up resistor } void loop() { switchState = digitalRead(switchPin); // Read the state of the switch if (switchState == LOW) { Serial.println("The switch is pressed!"); } else { Serial.println("The switch is not pressed."); } delay(200); // Small delay to avoid flooding the Serial Monitor }
Debouncing the Switch
Mechanical switches can generate noise due to bouncing contacts. To improve the reliability of your readings, you can implement software debouncing.
int switchState = 0; // Current state of the switch
int lastSwitchState = HIGH; // Previous state of the switch
unsigned long lastDebounceTime = 0; // Time of the last state change
unsigned long debounceDelay = 50; // Debounce time in milliseconds
int reading = digitalRead(switchPin);
if (reading != lastSwitchState) {
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
if (reading != switchState) {
switchState = reading;
} else {
lastSwitchState = reading;
Checks if the reading has changed from the last state.
If it has, resets the
lastDebounceTime.If the reading remains stable past the debounce delay, it considers the new state as valid.
Conclusion
In this lesson, you’ve learned how to use a micro switch with the Raspberry Pi Pico to detect when it’s pressed or released. You’ve also seen how to implement a pull-down resistor in the circuit to ensure reliable readings and how to use the internal pull-up resistor to simplify the circuit. Additionally, you’ve learned about debouncing to handle mechanical switch noise.
Further Exploration
Control an LED: Modify the code to turn an LED on when the switch is pressed.
Multiple Switches: Try adding more micro switches to detect different inputs.
Create a Counter: Count the number of times the switch is pressed and display it.
