š Ready to explore and create with us? Click [here] and join today!
2.10 Detect Human Movementļ
In this lesson, weāll learn how to use a Passive Infrared (PIR) sensor with the Raspberry Pi Pico 2 W to detect human movement. PIR sensors are commonly used in security systems, automatic lighting, and other applications where motion detection is required. They detect infrared radiation emitted by warm objects, such as humans or animals, in their field of view.
Itās definitely convenient to buy a whole kit, hereās the link:
PURCHASE LINK |
Pico 2 W Starter Kit |
450+ |
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Micro USB Cable |
Several |
Schematic
When the PIR module detects someone passing by, GP14 will be high, otherwise it will be low.
The PIR sensor have two potentiometers:
Sensitivity Adjustment: Controls the range of detection.
Time Delay Adjustment: Controls how long the output remains HIGH after motion is detected.
For initial testing, turn both potentiometers counterclockwise to their minimum positions. This sets the sensor to its most sensitive and shortest delay settings, allowing you to observe immediate responses.
Writing the Code
You can open the file
2.10_detect_human_movement.inounder the path ofpico-2w-kit-main/arduino/2.10_detect_human_movement.Or copy this code into Arduino IDE.
Donāt forget to select the board(Raspberry Pi Pico) and the correct port before clicking the Upload button.
const int pirPin = 14; // PIR sensor output pin connected to GP14
int pirState = LOW; // Current state of PIR sensor
int val = 0; // Variable to store the PIR reading
Serial.begin(115200); // Initialize Serial Monitor
pinMode(pirPin, INPUT); // Set the PIR pin as input
Serial.println("PIR Sensor Test");
delay(2000); // Allow the PIR sensor to stabilize
val = digitalRead(pirPin); // Read the PIR sensor
if (val == HIGH) {
if (pirState == LOW) {
Serial.println("Motion detected!");
pirState = HIGH;
} else {
if (pirState == HIGH) {
Serial.println("Motion ended!");
pirState = LOW;
delay(500); // Wait half a second before checking again
When the code is running and the Serial Monitor is open:
Move in front of the PIR sensor. The Serial Monitor should display āMotion detected!ā
Stop moving or move out of the sensorās range. After a short delay, the Serial Monitor should display āMotion ended!ā
Understanding the Code
Reading the PIR Sensor:
Reads the current state of the PIR sensor. It will be HIGH when motion is detected and LOW when no motion is detected.
Detecting Motion:
When motion is detected, and itās the first detection, it prints āMotion detected!ā and updates pirState.
When motion ends, it prints āMotion ended!ā and updates pirState.
if (val == HIGH) { if (pirState == LOW) { Serial.println("Motion detected!"); pirState = HIGH; } } else { if (pirState == HIGH) { Serial.println("Motion ended!"); pirState = LOW; } }
Practical Applications
Security Systems: Detect intruders or unauthorized movement.
Automatic Lighting: Turn lights on when motion is detected.
Energy Saving: Power down devices when no movement is detected for a period.
Troubleshooting Tips
False Triggers:
PIR sensors can be sensitive to environmental factors like temperature changes or sunlight.
Avoid pointing the sensor directly at heat sources or windows.
Sensor Not Detecting Motion:
Ensure the sensor has had time to initialize (some sensors require up to 60 seconds).
Adjust the sensitivity potentiometer.
Interference:
Keep the sensor away from electronics that may cause electromagnetic interference.
Conclusion
In this lesson, youāve learned how to use a PIR sensor with the Raspberry Pi Pico to detect human movement. Youāve set up the hardware, written code to read the sensorās output, and tested it to respond to motion. Understanding how to adjust the PIR sensorās settings allows you to tailor it to your specific application, whether itās for security, automation, or interactive projects.
