11. 视频小车
此程序为您提供 PiCar-X 的第一视角体验!通过键盘上的 WSAD 键控制方向, 使用 O 和 P 键调整速度。
运行代码
cd ~/picar-x/example
sudo python3 11.video_car.py
代码运行后,您可以看到 PiCar-X 拍摄的画面,并通过以下按键进行控制:
  • O: 加速
  • P: 减速
  • W: 前进
  • S: 后退
  • A: 左转
  • D: 右转
  • F: 停止
  • T: 拍照
  • Ctrl+C: 退出
查看画面
代码运行后,终端将显示以下提示:
No desktop !
* Environment: production
* Debug mode: off
然后您可以在浏览器中输入 http://<你的IP>:9000/mjpg 查看视频画面,例如: https://192.168.18.113:9000/mjpg
../_images/display1.png
代码
from picarx.utils import reset_mcu
from picarx import Picarx
from vilib import Vilib
from time import sleep, time, strftime, localtime
import readchar
import os
user = os.getlogin()
user_home = os.path.expanduser(f'~{user}')
reset_mcu()
sleep(0.2)
manual = '''
按下键盘按键以调用功能(不区分大小写):
    O: 加速
    P: 减速
    W: 前进
    S: 后退
    A: 左转
    D: 右转
    F: 停止
    T: 拍照
    Ctrl+C: 退出
px = Picarx()
def take_photo():
    _time = strftime('%Y-%m-%d-%H-%M-%S',localtime(time()))
    name = 'photo_%s'%_time
    path = f"{user_home}/Pictures/picar-x/"
    Vilib.take_photo(name, path)
    print('\nphoto save as %s%s.jpg'%(path,name))
def move(operate:str, speed):
    if operate == 'stop':
        px.stop()
        if operate == 'forward':
            px.set_dir_servo_angle(0)
            px.forward(speed)
        elif operate == 'backward':
            px.backward(speed)
        elif operate == 'turn left':
            px.set_dir_servo_angle(-30)
            px.forward(speed)
        elif operate == 'turn right':
            px.set_dir_servo_angle(30)
            px.forward(speed)
def main():
    speed = 0
    status = 'stop'
    Vilib.display(local=False,web=True)
    sleep(2)  # 等待启动
    print(manual)
        print("\rstatus: %s , speed: %s    "%(status, speed), end='', flush=True)
        # 读取按键
        key = readchar.readkey().lower()
        # 操作处理
        if key in ('wsadfop'):
            # 油门
            if key == 'o':
                if speed <=90:
                    speed += 10
            elif key == 'p':
                if speed >=10:
                    speed -= 10
                if speed == 0:
                    status = 'stop'
            # 方向控制
            elif key in ('wsad'):
                if speed == 0:
                    speed = 10
                if key == 'w':
                    # 倒车时限速,避免瞬间电流过大
                    if status != 'forward' and speed > 60:
                        speed = 60
                    status = 'forward'
                elif key == 'a':
                    status = 'turn left'
                elif key == 's':
                    if status != 'backward' and speed > 60: # 倒车时限速
                        speed = 60
                    status = 'backward'
                elif key == 'd':
                    status = 'turn right'
            # 停止
            elif key == 'f':
                status = 'stop'
            # 移动
            move(status, speed)
        # 拍照
        elif key == 't':
            take_photo()
        # 退出
        elif key == readchar.key.CTRL_C:
            print('\nquit ...')
            px.stop()
            Vilib.camera_close()
            break
        sleep(0.1)
if __name__ == "__main__":
        main()
    except Exception as e:
        print("error:%s"%e)
    finally:
        px.stop()
