记录新动作
我们使用键盘依次控制 PiCrawler 做出几个姿态,并将这些姿态记录下来,之后可以进行回放。
运行代码
cd ~/picrawler/examples
sudo python3 record_new_step_by_keyboard.py
代码运行后,请根据终端中弹出的提示进行操作。
按下
1234分别选择不同的脚,1: 右前脚,2: 左前脚,3: 左后脚,4: 右后脚按下
w、a、s、d、r、f来逐步控制 PiCrawler 的坐标值按下
space打印所有坐标值按下
p回放已记录的动作按下
esc退出程序
代码
from time import sleep
import sys
import tty
import termios
import copy
crawler = Picrawler()
speed = 80
def readchar():
fd = sys.stdin.fileno()
old_settings = termios.tcgetattr(fd)
tty.setraw(sys.stdin.fileno())
ch = sys.stdin.read(1)
finally:
termios.tcsetattr(fd, termios.TCSADRAIN, old_settings)
return ch
manual = '''
Press keys on keyboard to control!
w: Y++
a: X--
s: Y--
d: X++
r: Z++
f: Z--
1: Select right front leg
2: Select left front leg
3: Select left rear leg
4: Select right rear leg
Space: Print all leg coodinate & Save this step
p: Play all saved step
esc: Quit
new_step=[]
def save_new_step():
new_step.append(copy.deepcopy(crawler.current_step_all_leg_value()))
print(new_step)
def play_all_new_step():
for step in new_step:
crawler.do_step(step,speed)
sleep(0.6)
def main():
speed = 80
print(manual)
crawler.do_step('sit',speed)
leg = 0
coodinate=crawler.current_step_leg_value(leg)
key = readchar()
key = key.lower()
# print(key)
if 'w' == key:
coodinate[1]=coodinate[1]+2
elif 's' == key:
coodinate[1]=coodinate[1]-2
elif 'a' == key:
coodinate[0]=coodinate[0]-2
elif 'd' == key:
coodinate[0]=coodinate[0]+2
elif 'r' == key:
coodinate[2]=coodinate[2]+2
elif 'f' == key:
coodinate[2]=coodinate[2]-2
elif '1' == key:
leg=0
elif '2' == key:
leg=1
elif '3' == key:
leg=2
elif '4' == key:
leg=3
elif chr(32) == key:
print("[[right front],[left front],[left rear],[right rear]]")
print("saved new step")
print(crawler.current_step_all_leg_value())
save_new_step()
elif 'p' == key:
play_all_new_step()
elif chr(27) == key:# 27 for ESC
break
sleep(0.05)
crawler.do_single_leg(leg,coodinate,speed)
print("\n q Quit")
if __name__ == "__main__":
main()
它是如何工作的?
该项目基于 调整姿态 开发,并新增了动作记录与回放功能。
动作记录功能由以下代码实现:
new_step=[]
print(new_step)
备注
这里必须使用 Deep Copy ,否则在 append 时 new_step 不会得到一个新的数组对象。
动作回放功能由以下代码实现:
sleep(0.6)
