调整姿态
在本示例中,我们将通过键盘逐条腿地控制 PiCrawler,并调整到所需的姿态。
你可以按下空格键打印出当前的坐标值。在为 PiCrawler 创建独特的动作时,这些坐标值将非常有用。
运行代码
cd ~/picrawler/examples
sudo python3 do_single_leg.py
代码运行后,请根据终端中出现的提示进行操作。
按下
1234分别选择腿部,1:右前腿,2:左前腿,3:左后腿,4:右后腿按下
w、a、s、d、r、f可逐步调整 PiCrawler 的坐标值按下
Ctrl+C退出程序
代码
from time import sleep
import readchar
crawler = Picrawler()
SPEED = 80
STEP_SIZE = 2
manual = '''
-------- PiCrawler Controller ---------
<=| 2 |┌-┌┐┌┐-┐| 1 |=>
<=| 3 |└------┘| 4 |=>
1: Select right front leg
2: Select left front leg
3: Select left rear leg
4: Select right rear leg
W: Y++ R: Z++
A: X-- F: Z--
S: Y--
D: X++ Ctrl+C: Quit
legs_list = ['right front', 'left front', 'left rear', 'right rear']
# Axis mapping for cleaner logic
move_map = {
'w': (1, +STEP_SIZE), # Y++
's': (1, -STEP_SIZE), # Y--
'a': (0, -STEP_SIZE), # X--
'd': (0, +STEP_SIZE), # X++
'r': (2, +STEP_SIZE), # Z++
'f': (2, -STEP_SIZE), # Z--
def clear_screen():
print("\033[H\033[J", end='')
def show_info(selected_leg, coordinate):
clear_screen()
print(manual)
print(f"Selected leg: {selected_leg + 1} - {legs_list[selected_leg]}")
print(f"Coordinate: {coordinate}")
def main():
selected_leg = 0
print(manual)
# Stand up first
crawler.do_step('stand', 40)
sleep(0.5)
# Get current coordinates
coordinate = crawler.current_step_all_leg_value()
key = readchar.readkey().lower()
# Select leg
if key in ('1', '2', '3', '4'):
selected_leg = int(key) - 1
# Move selected leg
elif key in move_map:
axis, delta = move_map[key]
# Update coordinate
coordinate[selected_leg][axis] += delta
# Send updated position
crawler.do_single_leg(selected_leg, coordinate[selected_leg], SPEED)
sleep(0.1)
sleep(0.05)
print("\nExiting safely...")
finally:
# Return to sitting position on exit
crawler.do_step('sit', 40)
sleep(1)
except Exception:
print("Robot is now sitting. Program ended.")
if __name__ == "__main__":
main()
current_step_all_leg_value():返回所有腿部的坐标值do_single_leg(leg,coordinate[leg],speed):单独修改某条腿的坐标值
