情感机器人
这个示例展示了 PiCrawler 的一些有趣自定义动作。
运行代码
cd ~/picrawler/examples
sudo python3 emotional_robot.py
运行程序后,机器人首先会缓慢站立起来,以达到稳定的姿态。
随后,机器人会依次执行一系列动作,包括类似游泳的动作、俯卧撑、用前腿挥动打招呼的动作,以及扭动身体的舞蹈。这些动作按顺序执行,使机器人表现出动态且富有表现力的行为。
如果按下 Ctrl+C,程序会安全退出,机器人也会回到坐下的姿态。
代码
备注
你可以对下面的代码进行 Modify/Reset/Copy/Run/Stop 操作。但在此之前,请先进入源码路径,如 picrawler\examples 。修改完成后,可以直接运行查看效果。
from time import sleep
crawler = Picrawler()
def get_sit_step():
    # Get a valid sit step used as the base pose for hand actions
        return crawler.move_list['sit'][0]
    except Exception:
        return None
def handwork(speed):
    base = get_sit_step()
    # If a valid sit step cannot be retrieved, just perform a sit action
    if not base or len(base) < 4:
        crawler.do_step('sit', speed)
        sleep(0.6)
        return
    # Generate hand poses by modifying the sit step
    left_hand = crawler.mix_step(base, 0, [0, 50, 80])
    right_hand = crawler.mix_step(base, 1, [0, 50, 80])
    two_hand = crawler.mix_step(left_hand, 1, [0, 50, 80])
    sleep(0.6)
    crawler.do_step(left_hand, speed)
    sleep(0.6)
    crawler.do_step(two_hand, speed)
    sleep(0.6)
    crawler.do_step(right_hand, speed)
    sleep(0.6)
    sleep(0.6)
def twist(speed):
    # Initialize the base position for all four legs
    new_step = [[50, 50, -80], [50, 50, -80], [50, 50, -80], [50, 50, -80]]
    # Create a twisting motion by alternating rise and drop movements
    for i in range(4):
        for inc in range(30, 60, 5):
            rise = [50, 50, (-80 + inc * 0.5)]
            drop = [50, 50, (-80 - inc)]
            new_step[i] = rise
            new_step[(i + 2) % 4] = drop
            new_step[(i + 1) % 4] = rise
            new_step[(i - 1) % 4] = drop
            crawler.do_step(new_step, speed)
            sleep(0.02)
def pushup(speed):
    # Two poses used to simulate a push-up motion
    up = [[80, 0, -100], [80, 0, -100], [0, 120, -60], [0, 120, -60]]
    down = [[80, 0, -30], [80, 0, -30], [0, 120, -60], [0, 120, -60]]
    crawler.do_step(up, speed)
    sleep(0.6)
    crawler.do_step(down, speed)
    sleep(0.6)
def swimming(speed, loops=100):
    # Simulate a swimming-like motion by gradually adjusting leg coordinates
    for i in range(loops):
        crawler.do_step(
                [100 - i, i, 0],
                [100 - i, i, 0],
                [0, 120, -60 + i / 5],
                [0, 100, -40 - i / 5]
            speed
        sleep(0.01)
def main():
    speed = 100
        # Stand up slowly before performing actions
        crawler.do_step('stand', 40)
        sleep(1.0)
        swimming(speed)
        pushup(speed)
        handwork(speed)
        twist(speed)
        print("\nCtrl+C detected, exiting...")
    finally:
        # Return to a sitting posture before exiting
            crawler.do_step('sit', 40)
            sleep(1.0)
        except Exception:
if __name__ == "__main__":
    main()
工作原理
  1. 当程序启动时,机器人首先会缓慢站立起来,以达到稳定的姿态。
    sleep(1.0)
    站立完成后,程序会按顺序执行多个预定义动作。
  2. 游泳动作
    机器人通过逐渐改变四条腿的坐标,模拟类似游泳的运动。
        crawler.do_step([
            [100-i, i, 0],
            [100-i, i, 0],
            [0,120,-60+i/5],
            [0,100,-40-i/5]
        ], speed)
  3. 俯卧撑动作
    定义两个姿态来模拟俯卧撑的上下运动。
    up = [[80,0,-100],[80,0,-100],[0,120,-60],[0,120,-60]]
    down = [[80,0,-30],[80,0,-30],[0,120,-60],[0,120,-60]]
  4. 挥手动作
    程序使用 mix_step() 修改前腿的坐标, 从而实现挥手的动作效果。
    left_hand = crawler.mix_step(base,0,[0,50,80])
    right_hand = crawler.mix_step(base,1,[0,50,80])
  5. 扭动动作
    机器人通过抬起和降低对角线的腿来扭动身体。
    rise = [50,50,(-80+inc*0.5)]
    drop = [50,50,(-80-inc)]
  6. 如果按下 Ctrl+C,程序会安全退出,机器人会回到坐下的姿态。
