避障功能
在本项目中,PiCrawler 将使用超声波模块检测前方的障碍物。 当检测到障碍物时,PiCrawler 会发送信号,并寻找其他方向继续前进。
运行代码
cd ~/picrawler/examples
sudo python3 avoid.py
当程序启动时,PiCrawler 会站立起来。
它会持续使用超声波传感器测量距离, 并在终端中打印测量到的数值。
如果在 15 cm 范围内检测到障碍物: - 会播放警告声音。 - 机器人会进行一次小幅度左转。
如果前方路径是畅通的: - 机器人会向前移动。
机器人会持续自动避障运行,直到你按下 Ctrl+C。
在程序退出之前,机器人会安全地坐下。
代码
备注
你可以对下面的代码进行 Modify/Reset/Copy/Run/Stop 操作。但在此之前,需要先进入源码路径,如 picrawler\examples。修改代码后,可以直接运行查看效果。
from robot_hat import Music, Ultrasonic, Pin
import signal
music = Music()
crawler = Picrawler()
sonar = Ultrasonic(Pin("D2"), Pin("D3"))  # Ultrasonic trigger/echo pins
music.music_set_volume(100)  # Set speaker volume
alert_distance = 15  # Obstacle warning distance (cm)
speed = 80           # Movement speed
# Add hardware timeout to sonar.read()
# Prevent program from freezing
class Timeout(Exception):
def _alarm_handler(signum, frame):
    raise Timeout()
signal.signal(signal.SIGALRM, _alarm_handler)
# Read distance once with timeout protection
def safe_read_once(timeout_s=1):
        signal.alarm(timeout_s)
        d = sonar.read()
        signal.alarm(0)
        return d
    except Timeout:
        signal.alarm(0)
        return None
    except Exception:
        signal.alarm(0)
        return None
# Read multiple times and return median value (anti-noise)
def read_distance_filtered(n=5, gap=0.03, timeout_s=1):
    vals = []
    for _ in range(n):
        d = safe_read_once(timeout_s=timeout_s)
        if d is not None and d > 0:
            vals.append(d)
        time.sleep(gap)
    if not vals:
        return None
    vals.sort()
    return vals[len(vals)//2]  # Median filter
def main():
    distance = read_distance_filtered(n=5, gap=0.03, timeout_s=1)
    print("distance:", distance)
    if distance is None:
        time.sleep(0.15)  # Wait if read failed
        return
    if distance <= alert_distance:
        # Obstacle detected → play sound and turn
            music.sound_play_threading('./sounds/sign.wav', volume=100)
        except Exception as e:
            print("sound error:", e)
        crawler.do_action('turn left angle', 1, speed)
        time.sleep(0.5)  # Quiet window after movement
        # Path clear → move forward
        crawler.do_action('forward', 1, speed)
        time.sleep(0.4)
if __name__ == "__main__":
        crawler.do_step('stand', 40)  # Stand before starting
        time.sleep(1.0)
            main()
        print("\nStop.")
    finally:
            crawler.do_step('sit', 40)  # Sit before exit
            time.sleep(1.0)
        except Exception:
工作原理
  1. 初始化模块
    music = Music()
    alert_distance = 15
    speed = 80
    该代码块初始化三个主要模块: - music:用于控制声音播放。 - crawler:用于控制 PiCrawler 的运动。 - sonar:通过超声波传感器读取距离。
    同时还设置了扬声器音量、障碍物检测阈值(单位:厘米), 以及机器人的运动速度。
  2. 超时保护模块(防止 sonar.read() 卡死)
        raise Timeout()
    超声波驱动在等待回波信号时可能会阻塞程序。 该代码块安装了一个信号处理器,使程序可以中断 卡住的 sonar.read() 调用,从而保证程序继续运行。
  3. 函数:safe_read_once()
            d = sonar.read()
            signal.alarm(0)
            return d
        except Timeout:
            signal.alarm(0)
            return None
        except Exception:
            signal.alarm(0)
            return None
    该函数在带有超时保护的情况下读取一次超声波距离。
    • 如果读取成功,则返回距离值。
    • 如果读取超时或发生错误,则返回 None,避免程序卡死。
  4. 函数:read_distance_filtered()
        vals = []
        for _ in range(n):
                vals.append(d)
            time.sleep(gap)
        if not vals:
            return None
        vals.sort()
    该函数通过多次采样来提高测量可靠性:
    • 无效数据(None<= 0)会被忽略。
    • 将剩余的有效数据排序。
    • 返回中位数作为最终距离值,从而减少噪声影响。
  5. 函数:main()(核心决策与动作)
    def main():
        distance = read_distance_filtered(...)
            return
            music.sound_play_threading(...)
    这是主要的控制逻辑:
    • 读取经过过滤的距离值。
    • 如果读取失败,则跳过本次循环。
    • 如果检测到的障碍物距离小于 alert_distance, 则播放警告声音并向左转。
    • 否则机器人向前移动。
  6. 程序入口模块(循环运行 + 安全退出)
                main()
            print("\nStop.")
        finally:
    该代码块控制程序的整体运行流程:
    • 程序开始前,机器人先站立。
    • 在无限循环中不断执行 main()
    • 按下 Ctrl+C 可以终止程序。
    • 程序退出前,机器人会安全地坐下。
