👉 Ready to explore and create with us? Click [qui] and join today!
What Else Do You Need?
Before we start playing with this kit, let’s prepare the essential hardware.
  • Raspberry Pi
    The Raspberry Pi acts as the brain, handling all computing, sensing, and control tasks.
    • Compatible models: Raspberry Pi 5, Raspberry Pi 4, 3, or Raspberry Pi Zero 2W
    ../../_images/need_pi.jpg
  • Power Adapter
    Prepare a suitable power supply based on your Raspberry Pi model:
    ../../_images/need_power.png
    • Raspberry Pi 5: 5V 5A USB-C (recommended: official 27W PD power supply).
    • Raspberry Pi 4: 5V 3A USB-C.
    • Raspberry Pi 3B/3B+: 5V 2.5A Micro-USB.
    • Raspberry Pi Zero 2W: 5V 2A Micro-USB.
    Using a stable power source helps prevent undervoltage and ensures reliable operation.
  • Micro SD Card
    The Raspberry Pi does not have a built-in hard drive. It boots and stores all files on a Micro SD card.
    ../../_images/need_sd.jpg
    • Minimum: 16GB
    • Recommended: 32GB for better stability
    • Brand: Use reliable options such as SanDisk or Samsung to avoid read/write errors
Optional Components
Although not strictly required, the following peripherals will greatly improve your learning and debugging experience:
  • Monitor (HDMI or TV)
    For beginners, we strongly recommend a display with an HDMI input, so you can easily configure Raspberry Pi OS and run graphical programs.
    ../../_images/need_screen.png
  • HDMI Cable (Standard / Mini / Micro)
    Different Raspberry Pi models use different HDMI connectors, be sure to check your Pi model and prepare the correct cable.
    • Raspberry Pi 4 / 5: Micro HDMI
    • Raspberry Pi 3: Standard HDMI
    • Raspberry Pi Zero 2W: Mini HDMI
    ../../_images/need_hdmi.png
  • Keyboard & Mouse
    Very useful during the initial setup of Raspberry Pi OS. Later, you may switch to remote access (SSH/VNC), but for beginners we recommend preparing a basic USB or wireless set.
    ../../_images/need_keyboard_mouse.png
Tips for Preparation
  • If you purchased this kit, most accessories are included, but you still need to prepare the Raspberry Pi board, Micro SD card, and power adapter separately.
  • Not sure what to buy? The most stable and universal choice is: Raspberry Pi 4/5 (2GB) + Official Power Supply + 32GB Micro SD card.
