Lesson 17 Light Alarmο
Introductionο
This experiment is a very interesting one β a DIY phototransistor. DIY phototransistors use the glow effect and photoelectric effect of LEDs. That is, LEDs will generate weak currents when some light is shined on it. And we use a transistor to amplify the currents generated, so the SunFounder Uno board can detect them.
Componentsο
Experimental Principleο
LEDs not only have a glow effect, but also a photoelectric effect. They will generate weak currents when exposed to light waves.
NPN consists of a layer of P-doped semiconductor (the βbaseβ) between two N-doped layers (see the picture above). A small current entering the base is amplified to produce a large collector and emitter current. That is, when there is a positive potential difference measured from the emitter of a NPN transistor to its base (i.e., when the base is high relative to the emitter) as well as positive potential difference measured from the base to the collector, the transistor becomes active. In this βonβ state, current flows between the collector and emitter of the transistor.
A 10kΞ© pull-down resistor is attached to the transistor output stage in order to avoid analog port suspending to interfere with signals and cause misjudgment.
When the LED exposed to light waves, the LED generates weak currents, then the NPN transistor becomes active. Then read the analog value of A0, when A0>0, then set pin 5(buzzer) to high level.
The schematic diagram:
Experimental Procedures
Step 1: Build the circuit.
Step 2: Open the code file
Step 3: Select the correct Board and Port
Step 4: Upload the sketch to the board
Now, you can hear the buzzer beep when shining a flashlight on the LED.
You need to do this experiment in a dark environment, or the lights you give need to be much stronger than ambient light.
Codeο
Code Analysis 17-1 Whole Codeο
void setup()
Serial.begin(9600); // start serial port at 9600 bps:
void loop()
int n=analogRead(A0); //read the value from analog pin AO
Serial.println(n);
if(n>0) //If there is a voltage
pinMode(5,OUTPUT); //set the digital pin 5 as an output
tone(5,10000);
//Generates a square wave of the frequency of 10000 Hz (and 50% duty cycle) on pin 5
pinMode(5,INPUT); //set the pin 5 as an input
tone()ο
Descriptionο
Generates a square wave of the specified frequency (and 50% duty cycle) on a pin. A duration can be specified, otherwise the wave continues until a call to noTone(). The pin can be connected to a piezo buzzer or other speaker to play tones.
Only one tone can be generated at a time. If a tone is already playing on a different pin, the call to tone() will have no effect. If the tone is playing on the same pin, the call will set its frequency.
Use of the tone() function will interfere with PWM output on pins 3 and 11 (on boards other than the Mega).
Syntaxο
tone(pin, frequency)
tone(pin, frequency, duration)
Parametersο
pin: the pin on which to generate the tone
frequency: the frequency of the tone in hertz - unsigned int
duration: the duration of the tone in milliseconds (optional) - unsigned long
