Lesson 15 Voltmeterο
Introductionο
In this lesson, we will use two potentiometers and an LCD1602 to make a DIY voltmeter.
Componentsο
Experimental Principleο
Here one potentiometer is used to adjust the contrast of the LCD1602 and the other to divide voltage. When you adjust the potentiometer connected to pin A0 of the SunFounder Uno board, the resistance of the potentiometer will change and the voltage at pin A0 will change accordingly. This voltage change is converted into digital values by A/D converter on the SunFounder Uno board. We can see this change on the serial monitor. Then convert the digital values into voltage with the following formula: the voltage equals the digital value divides by 1024 and then multiplies by 5.0. Finally, display the voltage on the LCD1602.
The schematic diagram:
Experimental Proceduresο
Step 1: Build the circuit
Step 2: Open the code file
Step 3: Select the correct Board and Port
Step 4: Upload the sketch to the SunFounder Uno board
Now, adjust the potentiometer connected to pin A0, and you will see the voltage displayed on the LCD1602 varies accordingly.
Codeο
Code Analysis 15-1 Define the pins of LCD1602 andpotentiometerο
#include <LiquidCrystal.h>
float analogIn = 0; // store the analog value of A0
LiquidCrystal lcd(4, 6, 10, 11, 12, 13); // lcd(RS,E,D4,D5,D6.D7)
float vol = 0; // store the voltage
Call the LiquidCrystal library and define the pins of LCD1602 connect to 4,6 and 10 to 13 of Uno board.
Assign the value of A0 to analogIn.
Code Analysis 15-2 Initialize the LCD1602 and serial monitorο
void setup()
Serial.begin(9600); // Initialize the serial monitor
lcd.begin(16, 2); // set the position of the characters on the LCD as Line 2, Column 16
lcd.print("Voltage Value:"); // print "Voltage Value:"
Initialize the baud rate of serial monitor to 9600bps and set the position of the characters on the LCD as Line 2, Column 16. Print βVoltage Value: β on the LCD1602.
Code Analysis 15-3 Read the analog of A0 and convert to voltageο
void loop()
analogIn = analogRead(A0); // Read the value of the potentiometer to val
vol = analogIn/1024*5.0; // Convert the data to the corresponding voltage value in a math way
Serial.print(vol); // Print the number of val on the serial monitor
Serial.println("V"); // print the unit as V, short for voltage on the serial monitor
lcd.setCursor(6,1); // Place the cursor at Line 1, Column 6. From here the characters are to be displayed
lcd.print(vol); // Print the number of val on the LCD
lcd.print("V"); // Then print the unit as V, short for voltage on the LCD
delay(200); // Wait for 200ms
The analog value of A0 is: Analog value=5/VA0 * 1024, so VA0= Analog value/1024 * 5, if you connect the potentiometer to 3.3v, then modify 5V to 3.3V.
Print the voltage to serial monitor or the LCD1602.
