Projects
In this chapter, you will play with Scratch 3 through 18 projects.
If you are a user who has just used Scratch 3, we recommend that you try the projects in order so that you can quickly get started with Scratch 3.
Before trying the projects, you should have downloaded the relevant materials and code files. Open a Terminal and enter the following command to download them from github.
git clone https://github.com/sunfounder/davinci-kit-for-raspberry-pi.git --depth 1
