1.3 Tumbler
In this project, we will make a tilt switch controlled tumbler toy.
Build the Circuit
Load the Code and See What Happens
Load the code file (1.3_tumbler.sb3) to Scratch 3.
When the tilt switch is placed upright, the tumbler is standing. If you tilt it, the tumbler will also fall. Place it upright again, and the tumbler will stand up again.
Tips on Sprite
Select Sprite1 and click Costumes in the top left corner; upload tumbler1.png and tumbler2.png from the home/pi/davinci-kit-for-raspberry-pi/scratch/picture path via the Upload Costume button; delete the default 2 costumes, and rename the sprite to tumbler.
Tips on Codes
When the green flag is clicked, the initial state of gpio17 is set to low.
When pin17 is low (the tilt switch is placed upright), we switch the tumbler sprite’s costume to tumbler1 (upright state).
When pin17 is high (tilt switch is tilted), switch the tumbler sprite’s costume to tumbler2 (tilt state).
