1.1.2 RGB LEDο
Introductionο
In this project, we will control an RGB LED to flash various colors.
Componentsο
Schematic Diagramο
After connecting the pins of R, G, and B to a current limiting resistor, connect them to the GPIO17, GPIO18, and GPIO27 respectively. The longest pin (GND) of the LED connects to the GND of the Raspberry Pi. When the three pins are given different PWM values, the RGB LED will display different colors.
Experimental Proceduresο
Step 1: Build the circuit.
Step 3: Run the code.
sudo node rgb_led.js
After the code runs, you will see that RGB displays red, green, blue, yellow, pink, and cyan.
const ledred = new Gpio(17, { mode: Gpio.OUTPUT });
const ledgreen = new Gpio(18, { mode: Gpio.OUTPUT });
const ledblue = new Gpio(27, { mode: Gpio.OUTPUT });
function colorset(r, g, b) {
ledred.pwmWrite(r);
ledgreen.pwmWrite(g);
ledblue.pwmWrite(b);
var color_index = -1;
setInterval(() => {
color_index += 1;
switch (color_index) {
case 0:
colorset(0xff, 0x00, 0xFF);
break;
case 1:
colorset(0x00, 0xff, 0x00);
break;
case 2:
colorset(0x00, 0x00, 0xff);
break;
case 3:
colorset(0xff, 0xff, 0x00);
break;
case 4:
colorset(0xff, 0x00, 0xff);
break;
case 5:
colorset(0xc0, 0xff, 0x3e);
break;
default:
color_index=-1;
}, 500);
Code Explanation
const ledred = new Gpio(17,{mode: Gpio.OUTPUT});
const ledgreen = new Gpio(18,{mode: Gpio.OUTPUT});
const ledblue = new Gpio(27,{mode: Gpio.OUTPUT});
Initialize pins 17, 18, and 27 to output mode, and assign them to the constants ledred, ledgreen, and ledblue respectively.
function colorset(r,g,b){
ledred.pwmWrite(r);
Implement a colorset(r,g,b) function, which is used to write pulse values to pins 17, 18, 27. The Gpio library encapsulates the function pwmWrite() to write to pins Pulse value, the value is 0x00 to 0xff. Then you can write RGB values to the RGB LED through the colorset(r,g,b) function, so that it can display a variety of colors.
For questions about RGB, please refer to the website: https://www.rapidtables.com/web/color/RGB_Color.html
setInterval(() => {
color_index += 1;
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
default:
color_index=-1;
}, 500);
The RGB LED is controlled by colorset() executed every 500ms.
A switch case is used here to select the color emitted by the RGB LEDs.
Since color_index is changed by one every cycle, the color of this one RGB LED will change in order.
Phenomenon Pictureο
