6.2 Digital Dice¶
Here we use button, 7-segment and 74hc595 to make an electronic dice. Each time the button is pressed, a random number ranging from 1 to 6 is generated and displayed on the 7-segment Display.
3 in 1 Starter Kit |
380+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic
Open the
6.2.electronic_dice.inofile under the path of3in1-kit\basic_project\6.2.electronic_dice.Or copy this code into Arduino IDE.
Or upload the code through the Arduino Web Editor.
When the code is uploaded successfully, the 7-segment Display will display 0-7 in a fast scroll, and when you press the button, it will display a random number and stop scrolling. The scrolling display starts again when you press the button again.
How it works?
This project is based on 5.10 ShiftOut(Segment Display) with a button to start/pause the scrolling display on the 7-segment Display.
Initialize each pin and read the value of the button.
void setup () { ... attachInterrupt(digitalPinToInterrupt(buttonPin), rollDice, FALLING); }
The interrupt is used here to read the state of the button. The default value of
buttonPinis low, which changes from low to high when the button is pressed.rollDicerepresents the function to be called when the interrupt is triggered, it is used to toggle the value of the variablestate.FALLINGmeans the interrupt is triggered when thebuttonPingoes from low to high.
When the variable
stateis 0, the functionshowNumber()is called to make the 7-segment Display randomly display a number between 1 and 7.void loop() { if (state == 0) { showNumber((int)random(1, 7)); delay(50); } }
About
rollDice()function.void rollDice() { state = !state; }
When this function is called, it toggles the value of state, such as 1 last time and 0 this time.
About
showNumber()function.void showNumber(int num) { digitalWrite(STcp, LOW); //ground ST_CP and hold low for as long as you are transmitting shiftOut(DS, SHcp, MSBFIRST, datArray[num]); //return the latch pin high to signal chip that it //no longer needs to listen for information digitalWrite(STcp, HIGH); //pull the ST_CPST_CP to save the data }
This is the code inside
loop()in the project 5.10 ShiftOut(Segment Display) into the functionshowNumber().
