6.1 Light-sensitive Array¶
A photoresistor or photocell is a light-controlled variable resistor. The resistance of a photoresistor decreases with increasing incident light intensity; in other words, it exhibits photoconductivity. A photoresistor can be applied in light-sensitive detector circuits, and light- and darkness-activated switching circuits.
The resistance of a photoresistor changes with incident light intensity. If the light intensity gets higher, the resistance decreases; if it gets lower, the resistance increases. In this experiment, we will use eight LEDs to show the light intensity. The higher the light intensity is, the more LEDs will light up. When the light intensity is high enough, all the LEDs will be on. When there is no light, all the LEDs will go out.
3 in 1 Starter Kit |
380+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic
Open the
6.1.light_control_led.inofile under the path of3in1-kit\basic_project\6.1.light_control_led.Or copy this code into Arduino IDE.
Or upload the code through the Arduino Web Editor.
Now, shine some light on the photoresistor, and you will see several LEDs light up. Shine more light and you will see more LEDs light up. When you place it in a dark environment, all the LEDs will go out.
How it works?
void loop()
sensorValue = analogRead(photocellPin); //read the value of A0
ledLevel = map(sensorValue, 300, 1023, 0, NbrLEDs); // map to the number of LEDs
for (int led = 0; led < NbrLEDs; led++)//
if (led < ledLevel ) //When led is smaller than ledLevel, run the following code.
digitalWrite(ledPins[led], HIGH); // turn on pins less than the level
else
digitalWrite(ledPins[led],LOW); // turn off pins higher than
By using the map() function, you can map the photoresistor value to the 8 LEDs, for example, if sensorValue is 560, then ledLevel is 4, so at this point, ledPins[0] to ledPins[4] should be lit, and ledPins[5] to ledPins[7] should be off.
