.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _ar_eeprom: 6.2 Digital Dice ============================= Here we use button, 7-segment and 74hc595 to make an electronic dice. Each time the button is pressed, a random number ranging from 1 to 6 is generated and displayed on the 7-segment Display. **Required Components** In this project, we need the following components. It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - 3 in 1 Starter Kit - 380+ - |link_3IN1_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_uno` - |link_Uno_R3_buy| * - :ref:`cpn_breadboard` - |link_breadboard_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_resistor` - |link_resistor_buy| * - :ref:`cpn_button` - |link_button_buy| * - :ref:`cpn_74hc595` - |link_74hc595_buy| * - :ref:`cpn_7_segment` - |link_7segment_buy| **Schematic** .. image:: img/circuit_8.9_eeprom.png **Wiring** .. image:: img/wiring_electronic_dice.png :width: 800 :align: center **Code** .. note:: * Open the ``6.2.electronic_dice.ino`` file under the path of ``3in1-kit\basic_project\6.2.electronic_dice``. * Or copy this code into **Arduino IDE**. * Or upload the code through the `Arduino Web Editor `_. .. raw:: html When the code is uploaded successfully, the 7-segment Display will display 0-7 in a fast scroll, and when you press the button, it will display a random number and stop scrolling. The scrolling display starts again when you press the button again. **How it works?** This project is based on :ref:`ar_segment` with a button to start/pause the scrolling display on the 7-segment Display. #. Initialize each pin and read the value of the button. .. code-block:: arduino void setup () { ... attachInterrupt(digitalPinToInterrupt(buttonPin), rollDice, FALLING); } * The interrupt is used here to read the state of the button. The default value of ``buttonPin`` is low, which changes from low to high when the button is pressed. * ``rollDice`` represents the function to be called when the interrupt is triggered, it is used to toggle the value of the variable ``state``. * ``FALLING`` means the interrupt is triggered when the ``buttonPin`` goes from low to high. #. When the variable ``state`` is 0, the function ``showNumber()`` is called to make the 7-segment Display randomly display a number between 1 and 7. .. code-block:: arduino void loop() { if (state == 0) { showNumber((int)random(1, 7)); delay(50); } } #. About ``rollDice()`` function. .. code-block:: arduino void rollDice() { state = !state; } When this function is called, it toggles the value of state, such as 1 last time and 0 this time. #. About ``showNumber()`` function. .. code-block:: arduino void showNumber(int num) { digitalWrite(STcp, LOW); //ground ST_CP and hold low for as long as you are transmitting shiftOut(DS, SHcp, MSBFIRST, datArray[num]); //return the latch pin high to signal chip that it //no longer needs to listen for information digitalWrite(STcp, HIGH); //pull the ST_CPST_CP to save the data } This is the code inside ``loop()`` in the project :ref:`ar_segment` into the function ``showNumber()``.
