Klasse Servo
Beispiel
# Import Servo class
from robot_hat import Servo
# Create Servo object with PWM object
servo0 = Servo("P0")
# Set servo to position 0, here 0 is the center position,
# angle ranges from -90 to 90
servo0.angle(0)
# Sweep servo from 0 to 90 degrees, then 90 to -90 degrees, finally back to 0
for i in range(0, 91):
servo0.angle(i)
time.sleep(0.05)
for i in range(90, -91, -1):
servo0.angle(i)
time.sleep(0.05)
for i in range(-90, 1):
servo0.angle(i)
time.sleep(0.05)
# Servos are all controls with pulse width, some
# from 500 ~ 2500 like most from SunFounder.
# You can directly set the pulse width
# Set servo to 1500 pulse width (-90 degree)
servo0.pulse_width_time(500)
# Set servo to 1500 pulse width (0 degree)
servo0.pulse_width_time(1500)
# Set servo to 1500 pulse width (90 degree)
servo0.pulse_width_time(2500)
API
