Modul modules
Klasse Ultrasonic
Beispiel
# Import Ultrasonic and Pin class
from robot_hat import Ultrasonic, Pin
# Create Motor object
us = Ultrasonic(Pin("D2"), Pin("D3"))
# Read distance
distance = us.read()
print(f"Distance: {distance}cm")
API
Klasse ADXL345
Beispiel
# Import ADXL345 class
from robot_hat import ADXL345
# Create ADXL345 object
adxl = ADXL345()
# or with a custom I2C address
adxl = ADXL345(address=0x53)
# Read acceleration of each axis
x = adxl.read(adxl.X)
y = adxl.read(adxl.Y)
z = adxl.read(adxl.Z)
print(f"Acceleration: {x}, {y}, {z}")
# Or read all axis at once
x, y, z = adxl.read()
# Or print all axis at once
print(f"Acceleration: {adxl.read()}")
API
Klasse RGB_LED
Beispiel
# Import RGB_LED and PWM class
from robot_hat import RGB_LED, PWM
# Create RGB_LED object for common anode RGB LED
rgb = RGB_LED(PWM(0), PWM(1), PWM(2), common=RGB_LED.ANODE)
# or for common cathode RGB LED
rgb = RGB_LED(PWM(0), PWM(1), PWM(2), common=RGB_LED.CATHODE)
# Set color with 24 bit int
rgb.color(0xFF0000) # Red
# Set color with RGB tuple
rgb.color((0, 255, 0)) # Green
# Set color with RGB List
rgb.color([0, 0, 255]) # Blue
# Set color with RGB hex string starts with “#”
rgb.color("#FFFF00") # Yellow
API
Klasse Buzzer
Beispiel
Importieren und Initialisieren
# Import Buzzer class
from robot_hat import Buzzer
# Import Pin for active buzzer
from robot_hat import Pin
# Import PWM for passive buzzer
from robot_hat import PWM
# import Music class for tones
from robot_hat import Music
# Import time for sleep
music = Music()
# Create Buzzer object for passive buzzer
p_buzzer = Buzzer(PWM(0))
# Create Buzzer object for active buzzer
a_buzzer = Buzzer(Pin("D0"))
Aktives Summer-Signal
    a_buzzer.on()
    time.sleep(0.5)
    a_buzzer.off()
    time.sleep(0.5)
Passiver Summer Einfache Nutzung
# Play a Tone for 1 second
p_buzzer.play(music.note("C3"), duration=1)
# take adventage of the music beat as duration
# set song tempo of the beat value
music.tempo(120, 1/4)
# Play note with a quarter beat
p_buzzer.play(music.note("C3"), music.beat(1/4))
Passiver Summer Manuelle Steuerung
# Play a tone
p_buzzer.play(music.note("C4"))
# Pause for 1 second
time.sleep(1)
# Play another tone
p_buzzer.play(music.note("C5"))
time.sleep(1)
# Stop playing
p_buzzer.off()
Ein Lied spielen! Babyhai!
# Make a Shark-doo-doo function as is all about it
def shark_doo_doo():
    p_buzzer.play(music.note("C5"), music.beat(1/8))
    p_buzzer.play(music.note("C5"), music.beat(1/16))
    p_buzzer.play(music.note("C5"), music.beat(1/16 + 1/16))
# loop any times you want from baby to maybe great great great grandpa!
for _ in range(3):
    print("Measure 1")
    p_buzzer.play(music.note("G4"), music.beat(1/4))
    p_buzzer.play(music.note("A4"), music.beat(1/4))
    print("Measure 2")
    shark_doo_doo()
    p_buzzer.play(music.note("G4"), music.beat(1/8))
    p_buzzer.play(music.note("A4"), music.beat(1/8))
    print("Measure 3")
    shark_doo_doo()
    print("Measure 4")
    shark_doo_doo()
    print("Measure 5")
    p_buzzer.play(music.note("B4"), music.beat(1/4))
    time.sleep(music.beat(1/4))
API
Klasse Grayscale_Module
Beispiel
# Import Grayscale_Module and ADC class
from robot_hat import Grayscale_Module, ADC
# Create Grayscale_Module object, reference should be calculate from the value reads on white
# and black ground, then take the middle as reference
gs = Grayscale_Module(ADC(0), ADC(1), ADC(2), reference=2000)
# Read Grayscale_Module datas
datas = gs.read()
print(f"Grayscale Module datas: {datas}")
# or read a specific channel
l = gs.read(gs.LEFT)
m = gs.read(gs.MIDDLE)
r = gs.read(gs.RIGHT)
print(f"Grayscale Module left channel: {l}")
print(f"Grayscale Module middle channel: {m}")
print(f"Grayscale Module right channel: {r}")
# Read Grayscale_Module simple states
state = gs.read_status()
print(f"Grayscale_Module state: {state}")
API
