SunFounder pico_4wd_car
latest
  • Get Started
    • 1. Install Thonny IDE
    • 2. Install MicroPython on Your Pico
    • 3. Upload the Libraries to Pico
    • 4. Test the Modules
    • 5. Assemble the Car
    • 6. Examples
  • Appendix
  • FAQ
  • Thank You
  • Docs »
  • Get Started
  • Edit on GitHub
Get Started¶
In this section, you will learn all the hardware and software configurations needed to get Pico-4wd up and running, and it is recommended that you read them in order.
    • Power up the Pico RDP
    • Test the Motors
    • Test the Ultrasonic Module
    • Test the RGB Boards
    • Test the Grayscale Sensor Module
    • Test the Speed Module
    • Test the Servo
  • 6. Examples
    • Motor Calibration
    • Don’t Push Me
    • Line Track
    • Follow Your Hand
    • Obstacle Avoid
    • Control the Car with APP
Next Previous
© Copyright 2023, SunFounder Revision e8110348.
Built with Sphinx using a theme provided by Read the Docs.
