👉 Ready to explore and create with us? Click [aquí] and join today!
I²C Configuration
Follow the steps below to enable and test the I²C interface on your Raspberry Pi. These instructions apply to Raspberry Pi 5, 4, 3, and Zero 2W.
Enable the I²C Interface
  1. Open a terminal on your computer (Windows: PowerShell; macOS/Linux: Terminal) and connect to your Raspberry Pi:
    or:
    ssh <username>@<ip_address>
  2. Open the Raspberry Pi configuration tool:
    sudo raspi-config
  3. Select Interfacing Options and press Enter.
    ../../_images/ssh_interface.png
  4. Select I2C.
    ../../_images/ssh_i2c_i2c.png
  5. Choose <Yes>, then <Ok> → <Finish> to apply the changes. If prompted, reboot your Raspberry Pi.
    ../../_images/ssh_i2c_yes.png
Check I²C Kernel Modules
  1. Run the following command:
    lsmod | grep i2c
  2. If I²C is enabled, you will see modules such as:
    i2c_dev        6276    0
    i2c_bcm2708    4121    0
  3. If nothing appears, reboot the system:
    sudo reboot
Install i2c-tools
  1. Install the utilities required for scanning and testing I²C devices:
    sudo apt install i2c-tools
Detect Connected I²C Devices
  1. Scan the I²C bus:
    i2cdetect -y 1
  2. Example output:
    pi@raspberrypi ~ $ i2cdetect -y 1
        0  1  2  3   4  5  6  7  8  9   a  b  c  d  e  f
    00:           -- -- -- -- -- -- -- -- -- -- -- -- --
    10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    40: -- -- -- -- -- -- -- -- 48 -- -- -- -- -- -- --
    50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    70: -- -- -- -- -- -- -- --
  3. If a device is connected, its address (e.g., 0x48) will appear in the table.
Install the Python I²C Library
  1. Install the python3-smbus2 package:
    sudo apt install python3-smbus2
    The smbus2 library provides all the functions required to communicate with I²C devices in Python.
Your Raspberry Pi is now fully configured and ready to communicate with I²C devices.
