Adjust Posture¶
In this example, we use the remote function to control the PiCrawler foot by foot and assume the desired posture.
You can tap the button to print out the current coordinate values. These coordinate values come in handy when you create unique actions for PiCrawler.
../_images/1cood.A.png
Program
  • You can write the program according to the following picture, please refer to the tutorial: How to Create a New Project?.
  • Or find the code with the same name on the Examples page of the EzBlock Studio and click Run or Edit directly.
../_images/do_single_leg.png
Switch to the Remote Control interface, and you will see the following widgets.
../_images/do_single_leg_B-1.png
How it works?
What you need to pay attention to in this project are the following three blocks:
../_images/sp210928_115847.png
Modify the coordinate value of a certain leg individually.
../_images/sp210928_115908.png
Returns the coordinate value of the corresponding leg.
../_images/sp210928_115958.png
You may want to simplify the program with Functions, especially when you perform the same operation multiple times. Putting these operations into a newly declared function can greatly facilitate your use.
../_images/sp210928_135733.png
