Computer Vision¶
This project will officially enter the field of computer vision!
You can read How to Use the Video Function?. Come and carry out this project smoothly.
Program
  • You can write the program according to the following picture, please refer to the tutorial: How to Create a New Project?.
  • Or find the code with the same name on the Examples page of the EzBlock Studio and click Run or Edit directly.
../_images/sp210928_165255.png
Switch to the Remote Control interface, and you will see the following widgets.
../_images/sp210928_165642.png
After the program is running, you can switch the slider widget to turn on/off the face detection; click the D-Pad to select the color of the detection; click the button to print the detection result.
How it works?
../_images/sp210928_170920.png
This block is used to enable the camera module.
../_images/sp210928_171021.png
These two blocks are used to enable the face detection/color detection function.
../_images/sp210928_171125.png
These two blocks are used to output information. The detection result has five output values, namely coordinate x value, coordinate y value, width, height, and number.
