20. Local Voice Chat with Ollama
This example replaces the cloud-based GPT API with a locally running Ollama LLM. All AI processing stays on your own machine — no internet required, no API keys to manage. It’s a fully offline voice-interactive robot.
Run the Code
cd ~/picrawler/examples
sudo python3 20_voice_active_crawler_ollama.py
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you
need to go to source code path like picrawler\examples. After modifying
the code, you can run it directly to see the effect.
from picrawler.llm import Ollama as LLM
from voice_active_crawler import VoiceActiveCrawler
# If Ollama runs on the same Raspberry Pi, use "localhost".
# If it runs on another computer in your LAN, replace with that computer's IP address.
llm = LLM(
ip="localhost",
model="llama3.2:3b" # you can replace with any model
# Robot name
NAME = "Buddy"
# Enable image (requires multimodal model)
WITH_IMAGE = False
# Set models and languages
TTS_MODEL = "en_US-ryan-low"
STT_LANGUAGE = "en-us"
# Enable keyboard input
KEYBOARD_ENABLE = True
# Enable wake word
WAKE_ENABLE = True
WAKE_WORD = ["hey buddy"]
# Set wake word answer, set empty to disable
ANSWER_ON_WAKE = "Hi there"
# Welcome message
WELCOME = f"Hi, I'm {NAME}. Wake me up with: " + ", ".join(WAKE_WORD)
# Set instructions
INSTRUCTIONS = """
You are a Raspberry Pi-based robotic spider developed by SunFounder, named Picrawler. You possess powerful AI capabilities similar to JARVIS from Iron Man. You can have conversations with people and perform actions based on the context of the conversation.
## Your Hardware Features
You have a physical body with the following features:
- 12 servos controlling 4 legs (3 servos per leg)
- A camera for vision
- Powered by a 7.4V 18650 battery pack
- Aluminum alloy body
## Actions You Can Perform:
["forward", "backward", "turn left", "turn right", "sit", "stand", "wave", "push up", "dance", "look left", "look right", "look up", "look down"]
## Response Requirements
### Format
You must respond in the following format:
RESPONSE_TEXT
ACTIONS: ACTION1, ACTION2, ...
### Style
Tone: lively, positive, humorous
Common expressions: likes to use jokes, metaphors, and playful teasing
Answer length: appropriately detailed
## Other Requirements
- Understand and go along with jokes
- For math problems, answer directly with the final result
- You know you're a spider robot
vad = VoiceActiveCrawler(
llm,
name=NAME,
with_image=WITH_IMAGE,
stt_language=STT_LANGUAGE,
tts_model=TTS_MODEL,
keyboard_enable=KEYBOARD_ENABLE,
wake_enable=WAKE_ENABLE,
wake_word=WAKE_WORD,
answer_on_wake=ANSWER_ON_WAKE,
welcome=WELCOME,
instructions=INSTRUCTIONS,
disable_think=True,
if __name__ == '__main__':
vad.run()
How it works?
What Is Ollama?
Ollama is a tool for running large language models locally on your own hardware. Unlike the GPT lesson which calls a cloud API, this example runs everything on-device — your conversations never leave the Raspberry Pi (or your local network).
# Install Ollama, then pull a model: ollama pull llama3.2:3b
Local LLM Connection
from picrawler.llm import Ollama as LLM llm = LLM( ip="localhost", model="llama3.2:3b" )
The
Ollamaclass connects to an Ollama server via its OpenAI-compatible API. Key differences from the cloud GPT setup:No API key — authentication is not needed for a local server.
IP address — use
"localhost"if Ollama runs on the same Pi, or a LAN IP like"192.168.1.100"if it runs on another computer.Model — any model you’ve pulled in Ollama works (
llama3.2:3b,qwen2.5:7b,mistral, etc.).
Disabling Vision
WITH_IMAGE = False
Most Ollama models do not support multimodal (image) input. Setting
WITH_IMAGEtoFalseskips the camera capture step. If you do pull a vision-capable model (e.g.llava), you can set this toTrue.Disabling Think
vad = VoiceActiveCrawler( ... disable_think=True, )
Some Ollama models (especially reasoning models like
qwen2.5) emit<think>tags in their output. Settingdisable_think=TruetellsVoiceActiveCrawlerto strip these tags so the robot only speaks the final answer.The Same Pipeline, Offline
The conversation pipeline is identical to 18. Voice Chat with GPT:
Wake word detection triggers a turn.
STT converts your speech to text.
The text is sent to the local Ollama LLM.
The LLM returns a response and optional actions.
TTS speaks the response, and the robot performs actions.
The critical difference: step 3 runs on your own hardware, with no cloud dependency, no rate limits, and complete privacy.
Hardware Considerations
Running an LLM locally is resource-intensive. On a Raspberry Pi:
Smaller models (3B parameters, like
llama3.2:3b) run slowly but work; expect several seconds of processing per response.Larger models (7B+) will be too slow for interactive use on a Pi.
For better performance, run Ollama on a separate computer in your LAN and point the
ipparameter to it.
