15. STT (Speech-to-Text)
This example demonstrates how to use the STT (Speech-to-Text) module on PiCrawler. The robot listens to your voice through the onboard microphone and converts it into text in real time.
Run the Code
cd ~/picrawler/examples
sudo python3 15_stt.py
After running the program, you will see the language setting and a prompt. The robot starts listening — speak into the microphone and the recognized text will be printed to the terminal.
If no speech is detected, (no speech detected) is shown. Press Ctrl+C to exit.
Before You Start
Make sure you’ve completed:
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like picrawler\examples. After modifying the code, you can run it directly to see the effect.
from robot_hat.stt import STT
# Speech recognition demo using sunfounder_voice_assistant STT module
# Press Ctrl+C to exit
# Configure language: "en-us", "zh-cn", etc.
LANGUAGE = "en-us"
def main():
    print("=== PiCrawler Speech-to-Text Demo ===")
    print(f"Language: {LANGUAGE}")
    print("Press Ctrl+C to exit")
    print()
    stt = STT(language=LANGUAGE)
            print("Listening... (speak now)")
            text = stt.listen()
            if text:
                print(f">>> {text}")
                print("(no speech detected)")
        print("\nExiting...")
if __name__ == "__main__":
    main()
How it works?
  1. Importing the STT Module
    The STT class is part of the robot_hat package. It handles all the low-level audio capture and speech recognition processing.
  2. Setting the Language
    LANGUAGE = "en-us"
    The LANGUAGE variable configures the recognition language. You can change it to other supported codes such as "zh-cn" (Chinese) depending on your needs.
  3. Creating the STT Instance
    This creates an STT object configured for the chosen language. The object initializes the microphone and the speech recognition engine.
  4. The Listening Loop
        text = stt.listen()
        if text:
    The program runs an infinite loop where each iteration:
    • Prompts the user to speak.
    • Calls stt.listen() which blocks until speech is detected and processed.
    • Returns the recognized text as a string, or None / empty if nothing was understood.
    • Prints the result to the terminal.
  5. Graceful Exit
    Pressing Ctrl+C raises a KeyboardInterrupt, which is caught to print an exit message and terminate the program cleanly.
