16. TTS (Text-to-Speech)
This example demonstrates how to use the TTS (Text-to-Speech) module to make PiCrawler speak. It supports two engines: Piper (high-quality neural TTS) and Espeak (lightweight classic TTS). Type any text and the robot will read it aloud.
Run the Code
cd ~/picrawler/examples
sudo python3 16_tts.py
After running the program, the engine type and model are displayed. Type any
sentence and press Enter — the robot speaks it. Type quit to exit, or
press Ctrl+C.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you
need to go to source code path like picrawler\examples. After modifying
the code, you can run it directly to see the effect.
from robot_hat.tts import Piper, Espeak
# Text-to-Speech demo using robot_hat TTS module
# Press Ctrl+C to exit
# Set USE_PIPER=True for high-quality neural TTS (Piper), False for Espeak
USE_PIPER = True
# Piper model: "en_US-ryan-low" (English), "zh_CN-huayan-x_low" (Chinese)
TTS_MODEL = "en_US-ryan-low"
def main():
print("=== PiCrawler Text-to-Speech Demo ===")
if USE_PIPER:
print(f"Engine: Piper ({TTS_MODEL})")
tts = Piper(model=TTS_MODEL)
print("Engine: Espeak")
tts = Espeak()
print("Type text to speak, or 'quit' to exit")
print()
text = input("Text to speak: ").strip()
if text.lower() == 'quit':
break
if text:
print(f"Speaking: {text}")
tts.say(text)
print("\nExiting...")
if __name__ == "__main__":
main()
How it works?
Two TTS Engines Available
The
robot_hatpackage provides two TTS engines:Piper: A neural-network-based engine that produces natural, high-quality speech. Requires a voice model file.
Espeak: A lightweight, rule-based engine that runs on minimal resources.
Choosing the Engine and Model
USE_PIPER = True TTS_MODEL = "en_US-ryan-low"
Set
USE_PIPERtoTruefor Piper orFalsefor Espeak. When using Piper,TTS_MODELselects the voice. Common models include:"en_US-ryan-low"— American English male voice"zh_CN-huayan-x_low"— Chinese female voice
Creating the TTS Instance
if USE_PIPER: tts = Piper(model=TTS_MODEL) else: tts = Espeak()
Based on the
USE_PIPERflag, the appropriate engine is instantiated. Both engines share the samesay()interface, so switching engines requires no other code changes.The Input Loop
while True: text = input("Text to speak: ").strip() if text.lower() == 'quit': break if text: print(f"Speaking: {text}") tts.say(text)
The program prompts you for text:
Type any sentence and press Enter to make the robot speak.
Type
quitto exit the loop.Press Ctrl+C at any time to interrupt.
Contrast with STT
This lesson is the companion to 15. STT (Speech-to-Text). Together, STT (speech recognition) and TTS (speech synthesis) form the input and output halves of a voice interface for PiCrawler.
