19. Voice Chat with Doubao
This example uses Doubao (豆包), ByteDance’s large language model, as the AI brain of PiCrawler. The robot speaks Chinese, responds to the wake word “旺财”, and supports multimodal vision — it can see and describe what’s in front of it.
You need a Doubao API key from the Volcano Engine Ark Console. Store it in secret.py as DOUBAO_API_KEY.
Run the Code
cd ~/picrawler/examples
sudo python3 19_voice_active_crawler_doubao.py
After running, the robot initializes the STT engine, TTS engine (Chinese voice), Doubao LLM client, and wake word detector. It greets you in Chinese — say “旺财” to wake it up and start a conversation.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like picrawler\examples. After modifying the code, you can run it directly to see the effect.
from picrawler.llm import Doubao as LLM
from secret import DOUBAO_API_KEY as API_KEY
from voice_active_crawler import VoiceActiveCrawler
llm = LLM(
    api_key=API_KEY,
    model="doubao-seed-1-6-250615",
# 机器人的名字
NAME = "旺财"
# 是否开启图像识别,需要使用多模态的大语言模型
WITH_IMAGE = True
# 设置模型和语言
TTS_MODEL = "zh_CN-huayan-x_low"
STT_LANGUAGE = "cn"
# 是否开启键盘输入
KEYBOARD_ENABLE = True
# 是否开启唤醒词
WAKE_ENABLE = True
# 唤醒词
WAKE_WORD = ["旺财"]
# 唤醒词回答,设置为空字符串则不回答
ANSWER_ON_WAKE = "汪汪"
# 欢迎消息
WELCOME = f"你好,我是{NAME},叫我{WAKE_WORD[0]}唤醒我吧"
# Set instructions
INSTRUCTIONS = """
你是SunFounder旗下一款基于树莓派开发的蜘蛛机器人,叫做Picrawler。你有着强大的AI能力,类似钢铁侠中的JARVIS。你可以与人对话并根据对话上下文执行动作。
## 你的硬件特性
你拥有物理世界的身体,你的身体特性如下:
- 12个舵机控制4条腿(每条腿3个舵机)
- 摄像头用于视觉
- 使用7.4V的18650电池组供电
- 铝合金打造的身体
## 你可以执行的动作:
["forward", "backward", "turn left", "turn right", "sit", "stand", "wave", "push up", "dance", "look left", "look right", "look up", "look down"]
## 响应要求
### 格式
你必须按照以下格式响应:
RESPONSE_TEXT
ACTIONS: ACTION1, ACTION2, ...
### 风格
语调:活泼、积极、幽默
常用表达:喜欢使用笑话、隐喻和俏皮的调侃
回答长度:适当详细
## 其他要求
- 理解并配合笑话
- 对于数学问题,直接回答最终结果
- 你知道自己是一只蜘蛛机器人
- 不管如何你都要使用中文回复
vad = VoiceActiveCrawler(
    llm,
    name=NAME,
    with_image=WITH_IMAGE,
    stt_language=STT_LANGUAGE,
    tts_model=TTS_MODEL,
    keyboard_enable=KEYBOARD_ENABLE,
    wake_enable=WAKE_ENABLE,
    wake_word=WAKE_WORD,
    answer_on_wake=ANSWER_ON_WAKE,
    welcome=WELCOME,
    instructions=INSTRUCTIONS,
if __name__ == '__main__':
    vad.run()
How it works?
  1. Same Pipeline, Different Backend
    This lesson uses the same VoiceActiveCrawler framework introduced in 18. Voice Chat with GPT. The only changes are the LLM provider (Doubao instead of GPT) and the language configuration. See the comparison table in 18. Voice Chat with GPT for a side-by-side overview of all three backends.
  2. Connecting to Doubao
    llm = LLM(
        api_key=API_KEY,
    Doubao is ByteDance’s LLM, accessed via the Volcano Engine Ark API. The picrawler.llm module provides an OpenAI-compatible wrapper, so the interface is the same as the GPT lesson — only the import and model name differ.
    The model doubao-seed-1-6-250615 is a flagship multimodal model supporting both text and image input.
  3. Chinese Voice Configuration
    STT_LANGUAGE = "cn"
    To match the Chinese-speaking Doubao model, the TTS engine uses a Chinese female voice (huayan), and STT is set to recognize Chinese speech ("cn"). Compare with the English lessons which use "en-us" and "en_US-ryan-low".
  4. The Wake Word “旺财”
    WAKE_WORD = ["旺财"]
    “旺财” (Wàng Cái) is a traditional Chinese pet name meaning “prosperity.” When the robot hears this name, it responds with “汪汪” (woof woof) — playing the part of a loyal robotic pet.
  5. Chinese System Prompt
    The INSTRUCTIONS string is written entirely in Chinese. It defines the same structure as the English version — hardware description, available actions, response format, and personality — but also adds an extra rule:
    不管如何你都要使用中文回复
    (No matter what, you must reply in Chinese.) This ensures the robot stays in character as a Chinese-speaking companion.
  6. Vision with Doubao
    WITH_IMAGE = True
    Unlike most Ollama models, Doubao natively supports multimodal input. When WITH_IMAGE is enabled, the robot captures a photo and sends it to the Doubao API alongside your spoken question. The model can describe scenes, identify objects, and answer visual questions — all in Chinese.
