👉 Ready to explore and create with us? Click [hier] and join today!
PuTTY
PuTTY is a simple and reliable SSH client for Windows users to remotely access the Raspberry Pi.
Download PuTTY from PuTTY and install it on your computer.
Open PuTTY and prepare the connection:
Enter your Raspberry Pi’s hostname or IP address in Host Name.
Set the Port to
22.Click Open to connect.
If a security warning appears on first use, click Accept to continue.
Log in to the Raspberry Pi:
When you see login as:, enter the username you set in Raspberry Pi Imager.
Enter your password (it will not appear while typing—this is normal).
After logging in, the terminal is ready for you to enter commands and operate your Raspberry Pi remotely.
If PuTTY shows inactive, the connection was lost and needs to be reconnected.
