πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
1.2.2 Passive Buzzer
Introduction
In this project, we will learn how to make a passive buzzer play music.
Required Components
../_images/1.2.2_passive_buzzer_list.png
Schematic Diagram
In this experiment, a passive buzzer, a NPN transistor and a 1k resistor are used between the base of the transistor and GPIO to protect the transistor.
When GPIO17 is given different frequencies, the passive buzzer will emit different sounds; in this way, the buzzer plays music.
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
../_images/1.2.2_passive_buzzer_schematic.png
Experimental Procedures
Step 1: Build the circuit. (The Passive buzzer with green circuit board on the back.)
../_images/1.2.1_ActiveBuzzer_circuit.png
Step 2: Change directory.
Step 3: Run.
sudo python3 1.2.2_PassiveBuzzer.py
The code run, the buzzer plays a piece of music.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import TonalBuzzer
from time import sleep
# Initialize a TonalBuzzer connected to GPIO pin 17
tb = TonalBuzzer(17)  # Update this pin number based on your setup
def play(tune):
    Play a musical tune using the buzzer.
    :param tune: List of tuples (note, duration), where each tuple represents a note and its duration.
    for note, duration in tune:
        print(note)  # Output the current note being played
        tb.play(note)  # Play the note on the buzzer
        sleep(float(duration))  # Delay for the duration of the note
    tb.stop()  # Stop playing after the tune is complete
# Define a musical tune as a sequence of notes and durations
tune = [('C#4', 0.2), ('D4', 0.2), (None, 0.2),
    ('Eb4', 0.2), ('E4', 0.2), (None, 0.6),
    ('F#4', 0.2), ('G4', 0.2), (None, 0.6),
    ('Eb4', 0.2), ('E4', 0.2), (None, 0.2),
    ('F#4', 0.2), ('G4', 0.2), (None, 0.2),
    ('C4', 0.2), ('B4', 0.2), (None, 0.2),
    ('B4', 0.2), ('Bb4', 0.5), (None, 0.6),
    ('A4', 0.2), ('G4', 0.2), ('E4', 0.2),
    ('D4', 0.2), ('E4', 0.2)]
    play(tune)  # Execute the play function to start playing the tune
    # Handle KeyboardInterrupt for graceful termination
Code Explanation
  1. These lines import the TonalBuzzer class from the gpiozero library for buzzer control and the sleep function from the time module for creating delays.
  2. This line initializes a TonalBuzzer object on GPIO pin 17.
  3. The play function iterates over a list of tuples representing musical notes and their durations. Each note is played for its specified duration, and the buzzer stops after completing the tune.
    def play(tune):
  4. The tune is defined as a sequence of notes (frequency) and durations (seconds).
  5. The play(tune) function is called inside a try block. A KeyboardInterrupt (like Ctrl+C) will stop the program gracefully.
