1.2.1 Active Buzzer
In this project, we will learn how to drive an active buzzer to beep with a NPN transistor.
../_images/1.2.1_active_buzzer_list.png
Schematic Diagram
In this experiment, an active buzzer, an NPN transistor, and a 1kΩ resistor are used. The resistor is connected between the GPIO pin and the transistor’s base to limit the base current and protect the transistor. When GPIO17 on the Raspberry Pi outputs a high level (3.3V), the transistor enters saturation mode, allowing current to flow through the buzzer, which then sounds. When the GPIO17 outputs a low level (0V), the transistor is turned off, and the buzzer remains silent.
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
../_images/1.2.1_active_buzzer_schematic.png
Experimental Procedures
Step 1: Build the circuit. (The active buzzer has a white table sticker on the surface and a black back.)
../_images/1.2.1_ActiveBuzzer_circuit.png
Step 2: Open the code file.
Step 3: Run.
sudo python3 1.2.1_ActiveBuzzer.py
The code run, the buzzer beeps.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import Buzzer
from time import sleep
# Initialize a Buzzer object on GPIO pin 17
buzzer = Buzzer(17)
        # Turn on the buzzer
        print('Buzzer On')
        buzzer.on()
        sleep(0.1)  # Keep the buzzer on for 0.1 seconds
        # Turn off the buzzer
        print('Buzzer Off')
        buzzer.off()
        sleep(0.1)  # Keep the buzzer off for 0.1 seconds
    # Handle KeyboardInterrupt (Ctrl+C) for clean script termination
Code Explanation
  1. These statements import the Buzzer class from the gpiozero library and the sleep function from the time module.
  2. This line creates a Buzzer object connected to GPIO pin 17 on the Raspberry Pi.
    buzzer = Buzzer(17)
  3. In an infinite loop (while True), the buzzer is turned on and off every 0.1 seconds. print statements provide a console output for each action.
            print('Buzzer On')
            buzzer.on()
            print('Buzzer Off')
            buzzer.off()
  4. This segment ensures the program can be terminated safely using a keyboard interrupt (Ctrl+C) without throwing an error.
