Remote Desktop
You can access and control the Raspberry Pi desktop remotely from another computer. The recommended method is VNC, which is officially supported on Raspberry Pi OS and provides a reliable and consistent desktop experience.
The following section explains how to enable VNC on your Raspberry Pi and connect to it using RealVNC® Viewer.
Enable the VNC Service
RealVNC Server is preinstalled on Raspberry Pi OS, but it is disabled by default. You must enable it through the configuration tool.
  1. Open a terminal on your computer (Windows: PowerShell; macOS/Linux: Terminal) and connect to your Raspberry Pi:
    or
    ssh <username>@<ip_address>
  2. Run the configuration tool:
    sudo raspi-config
    ../../_images/ssh_raspi_config.png
  3. Select Interfacing Options and press Enter.
    ../../_images/ssh_interface.png
  4. Select VNC.
    ../../_images/ssh_vnc_vnc.png
  5. Choose Yes, then OK, and finally Finish to exit.
    ../../_images/ssh_vnc_enable.png
Log in with RealVNC® Viewer
  1. Download and install RealVNC® Viewer for your operating system.
    ../../_images/ssh_vnc_download.png
  2. Open RealVNC Viewer, then enter your Raspberry Pi’s IP address or <hostname>.local and press Enter.
    ../../_images/ssh_vnc_login.png
  3. Enter your Raspberry Pi’s username and password, then select OK.
    When connecting for the first time, you may see a message such as “VNC Server not recognized”. Select Continue to proceed.
    ../../_images/ssh_vnc_username.png
  4. You should now see the Raspberry Pi desktop:
    ../../_images/ssh_vnc_desktop.png
This completes the VNC setup process.
Additional Notes
  • Desktop version required
    • VNC requires the Raspberry Pi to be running the full desktop version of Raspberry Pi OS.
    • If you are using Raspberry Pi OS Lite, install VNC Server manually: sudo apt install realvnc-vnc-server
  • Network performance tips
    • If you experience lag or slow refresh rates, check your network quality.
    • Wired Ethernet generally offers the best performance.
  • Fixing display resolution issues
    • If the VNC window appears too small or the resolution is incorrect, set a fixed resolution via: sudo raspi-configDisplay OptionsVNC Resolution
  • Ensure VNC is enabled
    If VNC fails to connect, verify that it is enabled in: sudo raspi-configInterfacing OptionsVNC
  • Stopping the VNC service
    To manually stop the VNC Server: sudo systemctl stop vncserver-x11-serviced
  • Security reminder
    • VNC is designed for trusted local networks.
    • Do not expose VNC directly to the internet.
    • For secure remote access from outside your network, use Raspberry Pi Connect or a VPN.
