1.1.3 LED Bar Graphο
Introductionο
In this project, we sequentially illuminate the lights on the LED Bar Graph.
Componentsο
Principleο
LED Bar Graph
LED Bar Graph is an LED array, which is used to connect with electronic circuit or microcontroller. Itβs easy to connect LED bar graph with the circuit like as connecting 10 individual LEDs with 10 output pins. Generally we can use the LED bar graph as a Battery level Indicator, Audio equipments, and Industrial Control panels. There are many other applications of LED bar graphs.
Schematic Diagramο
T-Board Name |
physical |
wiringPi |
BCM |
GPIO17 |
Pin 11 |
0 |
17 |
GPIO18 |
Pin 12 |
18 |
GPIO27 |
Pin 13 |
27 |
GPIO22 |
Pin 15 |
22 |
GPIO23 |
Pin 16 |
23 |
GPIO24 |
Pin 18 |
24 |
GPIO25 |
Pin 22 |
25 |
SDA1 |
Pin 3 |
8 |
SCL1 |
Pin 5 |
9 |
SPICE0 |
Pin 24 |
10 |
8 |
Experimental Proceduresο
Step 1: Build the circuit.
For C Language Usersο
cd ~/davinci-kit-for-raspberry-pi/c/1.1.3/
Step 3: Compile the code.
gcc 1.1.3_LedBarGraph.c -lwiringPi
After the code runs, you will see the LEDs on the LED bar turn on and off regularly.
#include <wiringPi.h>
#include <stdio.h>
int pins[10] = {0,1,2,3,4,5,6,8,9,10};
void oddLedBarGraph(void){
for(int i=0;i<5;i++){
int j=i*2;
digitalWrite(pins[j],HIGH);
delay(300);
digitalWrite(pins[j],LOW);
void evenLedBarGraph(void){
int j=i*2+1;
delay(300);
void allLedBarGraph(void){
for(int i=0;i<10;i++){
digitalWrite(pins[i],HIGH);
delay(300);
digitalWrite(pins[i],LOW);
int main(void)
for(int i=0;i<10;i++){ //make led pins' mode is output
pinMode(pins[i], OUTPUT);
oddLedBarGraph();
delay(300);
evenLedBarGraph();
delay(300);
allLedBarGraph();
delay(300);
Code Explanation
Create an array and assign it to the pin number corresponding to the LED Bar Graph (0,1,2,3,4,5,6,8,9,10) and the array will be used to control the LED.
int j=i*2;
delay(300);
Let the LED on the odd digit of the LED Bar Graph light on in turn.
int j=i*2+1;
delay(300);
Make the LED on the even digit of the LED Bar Graph light on in turn.
delay(300);
Let the LED on the LED Bar Graph light on one by one.
For Python Language Usersο
Step 3: Run the executable file.
sudo python3 1.1.3_LedBarGraph.py
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python.
import RPi.GPIO as GPIO
ledPins = [11, 12, 13, 15, 16, 18, 22, 3, 5, 24]
def oddLedBarGraph():
for i in range(5):
j = i*2
GPIO.output(ledPins[j],GPIO.HIGH)
time.sleep(0.3)
GPIO.output(ledPins[j],GPIO.LOW)
def evenLedBarGraph():
for i in range(5):
j = i*2+1
time.sleep(0.3)
def allLedBarGraph():
for i in ledPins:
GPIO.output(i,GPIO.HIGH)
time.sleep(0.3)
GPIO.output(i,GPIO.LOW)
def setup():
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BOARD) # Numbers GPIOs by physical location
for i in ledPins:
GPIO.setup(i, GPIO.OUT) # Set all ledPins' mode is output
GPIO.output(i, GPIO.LOW) # Set all ledPins to high(+3.3V) to off led
def loop():
oddLedBarGraph()
time.sleep(0.3)
evenLedBarGraph()
time.sleep(0.3)
allLedBarGraph()
time.sleep(0.3)
def destroy():
for pin in ledPins:
GPIO.output(pin, GPIO.LOW) # turn off all leds
GPIO.cleanup() # Release resource
setup()
loop()
destroy()
Code Explanation
ledPins = [11, 12, 13, 15, 16, 18, 22, 3, 5, 24] Create an array and assign it to the pin number corresponding to the LED Bar Graph (11, 12, 13, 15, 16, 18, 22, 3, 5, 24) and the array will be used to control the LED.
for i in range(5):
j = i*2
time.sleep(0.3)
for i in range(5):
j = i*2+1
time.sleep(0.3)
for i in ledPins:
time.sleep(0.3)
Phenomenon Pictureο
