1.2 Beep¶
The active buzzer is a typical digital output device that is as easy to use as lighting up an LED!
Two types of buzzers are included in the kit. We need to use active buzzer. Turn them around, the sealed back (not the exposed PCB) is the one we want.
3 in 1 Starter Kit |
380+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic
You can open the file
1.2.beep.inounder the path of3in1-kit\basic_project\1.2.beep.Or copy this code into Arduino IDE.
Or upload the code through the Arduino Web Editor.
After the code is uploaded successfully, you will hear a beep every second.
