Powered by PiPower
  • TS7-Pro Screen
  • PiPower + 2 18650 batteries (self-provided)
  • Raspberry Pi (Self-provided)
Hole size for mounting the PiPower:
../_images/power8.png
Mount the PiPower
If you buy our PiPower, you can use it to power the TS7-Pro screen directly, so you can easily get it for outdoor use. The specific installation tutorial is as follows.
  1. Remove the Protective Cover Plate.
    ../_images/power1.jpg
  2. Secure the PiPower to the Protective Cover Plate. Note that the M2.5x6mm screws in the PiPower are required here.
    ../_images/power2.jpg
  3. Put the Protective Cover Plate back on.
    ../_images/power3.jpg
  4. Connect the PiPower to the Raspberry Pi with a USB cable.
    ../_images/power4.jpg
  5. Turning the PiPower switch to ON will allow the Raspberry Pi to boot up.
    ../_images/power6.jpg
