Assemble and Use a Camera Module
  • TS7-Pro Screen
  • Camera Module (Self-provided)
  • Raspberry Pi (Self-provided)
Hole size for mounting the Camera module:
../_images/camera5.png
Mount Camera Module
Refer to the following tutorial to mount the camera module.
../_images/camera1.jpg
Enable the Camera
Open Raspberry Pi Configuration.
../_images/raspbian1.png
In the Interfaces option, Enable the Camera, and then click OK.
../_images/raspbian2.png
In the pop-up prompt box, choose to restart now.
../_images/raspbian3.png
After the restart is complete, use the following command line to check whether the camera is available.
If the camera screen appears it means that the camera is installed successfully. Otherwise the FFC cable needs to be unplugged and plugged in again.
raspivid -o vid.h264
