πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
FAQ
The screen shows No Signal after the device is turned on?
  • Please check if all the cables are plugged in properly.
  • Check if the control board (Raspberry Pi) is on.
  • Check if the SD card has the correct system installed.
Can’t touch?
  • Make sure the touch module is connected to the control board (or device) via the USB touch cable.
  • Check if the touch module is damaged, if so please contact us.
Use of the touch pen
  • This display works with passive capacitive stylus, while active capacitive does not.
The LCD display cannot be turned on without connecting other devices.
  • This is a normal phenomenon, please use it after connecting Raspberry Pi or other devices.
