Widgets List¶
Icon |
Event |
Value |
Slider |
Hold the dot to move |
Default: 0~100, range and initial value can be changed. |
Guage |
Show widget |
Default: 0~100, range and unit can be changed. |
Radar |
Show widget |
Shows ultrasonic module direction and surrounding obstacles. |
Greyscale Indicator |
Show widget |
Black, white, or cliff are shown based on the set value. |
In the
area (C/E/F/G/I/J/M/N/O/P and Q/R/S/T area in single joystick mode), there are the following widgets.
Icon |
Event |
Value |
Button |
Press or Release |
Press(True), Release(False) |
Microphone |
Hold and speak in English. |
Return to what you said |
Number |
Show widget |
float value |
Switch |
Tap to ON or OFF |
ON(True), OFF(False) |
Icon |
Event |
Value |
Joystick |
Hold the circle to move |
-100 ~ 100 in X-axis and Y-axis |
D-pad |
Tap each arrow key |
“up”, “down”, “left”, “right” |
Throttle |
Up or down the handle |
-100 ~ 100 |
