How to Create a Controller?ΒΆ
Open the APP and tap the + button on the home page to create a controller.
There are preset controllers available for some of our robot kits, so you can choose as you need. Here we choose Blank and Dual Stick.
Now we get an empty controller.
A controller has three different shapes of squares for adding widgets. Choose the widget from the pop-up widget list according to your needs by tapping the + sign.
In order to easily know its functions and working range, you need to set it up by tapping on the
button.
Set the Maximum and Minimum, then tap to Confirm.
After finishing the widget settings, tap the
button.
