2.2.2 Thermistor(MCP3008)
Just like photoresistor can sense light, thermistor is a temperature sensitive electronic device that can be used for realizing functions of temperature control, such as making a heat alarm.
../_images/list2_2.2.2_thermistor.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
Thermistor
MCP3008
Schematic Diagram
T-Board Name
physical
WiringPi
SPICE0
pin24
10
8
SPIMOSI
pin19
12
10
SPIMISO
pin21
13
9
SPISCLK
pin23
14
11
../_images/schematic_2.2.2_thermistor_mcp3008.png
Experimental Procedures
Step 1: Build the circuit.
../_images/july24_2.2.2_thermistor_mcp3008.png
Step 2: Set up the SPI interface and install the spidev library (see SPI Configuration for detailed instructions). If you have already completed these steps, you can skip this.
Step 3: Go to the folder of the code.
cd ~/raphael-kit/python
Step 4: Run the executable file
sudo python3 2.2.2-2_thermistor.py
With the code run, the thermistor detects ambient temperature which will be printed on the screen once it finishes the program calculation.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
# -*- coding: utf-8 -*-
import spidev
import math
import RPi.GPIO as GPIO
# Set GPIO mode
GPIO.setmode(GPIO.BCM)
# Initialize SPI for MCP3008 (Bus 0, CE0)
spi = spidev.SpiDev()
spi.open(0, 0)  # Bus 0, Device 0 (CE0)
def read_adc(channel):
    Read analog value from MCP3008 channel (0–7)
        return -1
    return value
        # Read analog value from CH0 of MCP3008
        analogVal = read_adc(0)
        # Convert to voltage (assuming 3.3V reference)
        Vr = 3.3 * analogVal / 1023.0
        # Calculate thermistor resistance (R2 in voltage divider is 10kΩ)
        Rt = 10000.0 * Vr / (3.3 - Vr)
        # Steinhart–Hart calculation
        tempK = 1.0 / (((math.log(Rt / 10000.0)) / 3950.0) + (1.0 / (273.15 + 25.0)))
        # Convert to Celsius and Fahrenheit
        Cel = tempK - 273.15
        Fah = Cel * 1.8 + 32
        # Print the result
        print('Celsius: %.2f °C  Fahrenheit: %.2f °F' % (Cel, Fah))
        time.sleep(0.2)
finally:
    spi.close()
    GPIO.cleanup()
Code Explanation
  1. This section imports required libraries:
    • spidev for SPI communication with MCP3008
    • time for delay functionality
    • math for logarithmic operations in the Steinhart–Hart temperature formula
    • RPi.GPIO for initializing and cleaning up GPIO (included for structural completeness)
    import spidev
    import math
  2. Initializes the GPIO mode as BCM and configures the SPI interface on bus 0 and device 0 (CE0), with a speed of 1 MHz.
    # Set GPIO mode
  3. Defines a function read_adc(channel) to read analog values from a specified MCP3008 channel (0–7). It sends a 3-byte SPI command and receives a 10-bit analog result (0–1023).
            return -1
        return value
  4. Main loop: Reads analog voltage from a thermistor on channel 0, converts it to resistance, then uses the Steinhart–Hart equation to estimate temperature in Celsius and Fahrenheit. Updates are printed every 0.2 seconds.
            # Print the result
            time.sleep(0.2)
  5. The finally block ensures graceful shutdown. It closes the SPI interface and performs GPIO cleanup to release all hardware resources.
    finally:
        spi.close()
        GPIO.cleanup()
