2.2.1 Photoresistor(MCP3008)ο
Introductionο
Photoresistor is a commonly used component of ambient light intensity in life. It helps the controller to recognize day and night and realize light control functions such as night lamp. This project is very similar to potentiometer, and you might think it changing the voltage to sensing light.
Required Componentsο
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagramο
T-Board Name |
physical |
WiringPi |
BCM |
SPICE0 |
pin24 |
10 |
8 |
SPIMOSI |
pin19 |
12 |
10 |
SPIMISO |
pin21 |
13 |
9 |
SPISCLK |
pin23 |
14 |
11 |
GPIO22 |
pin15 |
22 |
Experimental Proceduresο
Step 1: Build the circuit.
Step 2: Set up the SPI interface and install the spidev library (see SPI Configuration for detailed instructions). If you have already completed these steps, you can skip this.
Step 3: Go to the folder of the code.
cd ~/raphael-kit/python
sudo python3 2.2.1-2_photoresistor.py
When the code is running, the brightness of the LED will change according to the light intensity sensed by the photoresistor.
Warning
If there is an error prompt RuntimeError: Cannot determine SOC peripheral base address, please refer to If gpiozero doesnβt work.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
import spidev
# GPIO pin for PWM LED
PWM_PIN = 22
# Setup GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(PWM_PIN, GPIO.OUT)
# Initialize PWM (frequency = 1000Hz)
pwm = GPIO.PWM(PWM_PIN, 1000)
pwm.start(0) # Start with 0% duty cycle
# Initialize SPI (MCP3008 on Bus 0, CE0)
spi = spidev.SpiDev()
spi.open(0, 0)
spi.max_speed_hz = 1000000 # 1 MHz
# Function to read MCP3008 ADC value
def read_adc(channel):
Read analog value from MCP3008 (channel 0β7)
Returns: 10-bit value (0β1023)
return -1
value = ((r[1] & 3) << 8) | r[2]
return value
# Main loop to read ADC and set PWM brightness
analogVal = read_adc(0)
print(f"value = {analogVal}")
# Scale ADC value (0β1023) to duty cycle (0β100)
duty_cycle = analogVal * 100 / 1023
pwm.ChangeDutyCycle(duty_cycle)
time.sleep(0.2)
finally:
pwm.stop()
GPIO.cleanup()
spi.close()
Code Explanation
Import necessary libraries:
RPi.GPIOto control GPIO pins and generate PWM signal.spidevto interface with the MCP3008 ADC via SPI.timeto handle timing and delays.
#!/usr/bin/env python3 import RPi.GPIO as GPIO import spidev import time
Configure GPIO pin 22 as PWM output using BCM mode. Then, initialize software PWM at 1000 Hz with a starting duty cycle of 0%.
# GPIO pin for PWM LED PWM_PIN = 22 # Setup GPIO GPIO.setmode(GPIO.BCM) GPIO.setup(PWM_PIN, GPIO.OUT) # Initialize PWM (frequency = 1000Hz) pwm = GPIO.PWM(PWM_PIN, 1000) pwm.start(0) # Start with 0% duty cycle
Set up the SPI interface to communicate with MCP3008 on bus 0, chip enable 0 (CE0), and configure SPI speed to 1 MHz.
# Initialize SPI (MCP3008 on Bus 0, CE0) spi = spidev.SpiDev() spi.open(0, 0) spi.max_speed_hz = 1000000 # 1 MHz
Define a function
read_adc(channel)to read analog values from MCP3008. The function sends three bytes to the chip and reconstructs a 10-bit analog value (0β1023) from the response.# Function to read MCP3008 ADC value def read_adc(channel): """ Read analog value from MCP3008 (channel 0β7) Returns: 10-bit value (0β1023) """ if channel < 0 or channel > 7: return -1 r = spi.xfer2([1, (8 + channel) << 4, 0]) value = ((r[1] & 3) << 8) | r[2] return value
This is the main loop that: - Reads analog input from channel 0 of the MCP3008. - Converts the value to a PWM duty cycle (0β100%). - Adjusts the brightness of the LED using
pwm.ChangeDutyCycle(). - Repeats every 0.2 seconds.# Main loop to read ADC and set PWM brightness try: while True: analogVal = read_adc(0) print(f"value = {analogVal}") # Scale ADC value (0β1023) to duty cycle (0β100) duty_cycle = analogVal * 100 / 1023 pwm.ChangeDutyCycle(duty_cycle) time.sleep(0.2)
When the user interrupts the program with Ctrl+C, the PWM and GPIO are properly cleaned up, and the SPI interface is closed.
except KeyboardInterrupt: pass finally: pwm.stop() GPIO.cleanup() spi.close()
