2.1.9 Joystick(MCP3008)
In this project, We’re going to learn how joystick works. We manipulate the Joystick and display the results on the screen.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
When the data of joystick is read, there are some differents between axis: data of X and Y axis is analog, which need to use MCP3008 to convert the analog value to digital value. Data of Z axis is digital, so you can directly use the GPIO to read, or you can also use ADC to read.
Experimental Procedures
Step 1: Build the circuit.
Step 2: Set up the SPI interface and install the spidev library (see SPI Configuration for detailed instructions). If you have already completed these steps, you can skip this.
Step 3: Go to the folder of the code.
cd ~/raphael-kit/python
Step 4: Run.
sudo python3 2.1.9-2_Joystick.py
After the code runs, turn the Joystick, then the corresponding values of x, y, Btn are displayed on screen.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
import spidev
# Define GPIO pin for joystick button (SW pin)
BTN_PIN = 22
# Set up GPIO mode
GPIO.setmode(GPIO.BCM)
GPIO.setup(BTN_PIN, GPIO.IN, pull_up_down=GPIO.PUD_UP) # Use internal pull-up
# Initialize SPI communication with MCP3008
spi = spidev.SpiDev()
spi.open(0, 0) # SPI bus 0, CE0
spi.max_speed_hz = 1000000 # 1 MHz
def read_adc(channel):
Reads analog value from the specified MCP3008 channel (0–7)
:param channel: ADC channel number (0–7)
:return: 10-bit integer value (0–1023)
return -1
return value
# Main loop to read and print joystick values and button state
# Read X and Y values from MCP3008 channels 1 and 2
x_val = read_adc(1) # Joystick VRX connected to CH1
y_val = read_adc(2) # Joystick VRY connected to CH2
# Read the state of the joystick button (SW)
Btn_val = GPIO.input(BTN_PIN) # 0 = pressed, 1 = released
# Print the read values
print('X: %d Y: %d Btn: %d' % (x_val, y_val, Btn_val))
time.sleep(0.2)
finally:
spi.close()
GPIO.cleanup()
Code Explanation
import spidev
This section imports the required libraries:
RPi.GPIOis used to handle GPIO input (joystick button).spidevis used to communicate with the MCP3008 ADC chip via SPI.timeis used to introduce delays between readings.
BTN_PIN = 22
# Set up GPIO mode
This block sets the GPIO mode to BCM, initializes the joystick button input on GPIO22 with a pull-up resistor, and configures the SPI interface with MCP3008 using bus 0 and chip enable 0 (CE0) at 1 MHz.
return -1
return value
Defines the read_adc() function to read analog data from a specific MCP3008 channel. It sends three bytes over SPI and interprets the response to return a 10-bit value from 0 to 1023.
# Read X and Y values from MCP3008 channels 0 and 1
x_val = read_adc(0) # Joystick VRX connected to CH0
y_val = read_adc(1) # Joystick VRY connected to CH1
time.sleep(0.2)
finally:
spi.close()
GPIO.cleanup()
This main loop reads and prints the X/Y analog positions from the joystick and its button state every 200ms. If the script is interrupted via keyboard (Ctrl+C), SPI and GPIO are properly cleaned up.
